Results 1 to 5 of 5
Thread: On the column
    Senior Member MisterAdam's Avatar
    Brentwood NH
    On the column
    Ok no laughing!! Does anyone make a 4 speed on the column? I thing it would be perfect in the 33.
    Not laughing at all. Ididit makes a very cool steering column with column mounted linkage. It’s called the 40’s Style Straight. It’s really sharp. I thought it would be great in the truck.
    https://www.ididitinc.com/i-26432621...tegory:1341771
    Kingsland, TX
    I believe ididit makes the FFR column... They make several different columns with shifters. It might be worth a call to them to see what they can do for you.
    Senior Member JOP33's Avatar
    Haslet, Texas
    I had actually contemplated early on (at the suggestion of MBB Larry) a push button control for my transmission but decided not to go that route.
    Brentwood NH
    Seems like this is for a 4 speed automatic. I was thinking of a 4 speed manual.
