Thanks Thanks:  2
Likes Likes:  2
Results 1 to 26 of 26
Thread: radiator reservoir
    Falmouth, MA
    Question radiator reservoir
    Am I confused (happens all the time) but isn't the overflow can included with the complete kit? None with mine so I guess I need to go find one.
    Quote Originally Posted by cob427sc View Post
    Yes, the complete kit comes with an overflow tank. Check your inventory. If it isn't on there, call FFR and see if they can help you out.
    Nov 2015
    Elverta, CA
    If not, let me know and I will send mine which I didn't use.
    Falmouth, MA
    Did not show up on the inventory, nor is it listed on the b/o list. I only realized it wasn't there as I am that far along on the build. I'll check with FFR but I'm way beyond my 45 days.
    I just realized that you are building a 33. I know it's part of the roadster complete kit, but can't say for sure for the 33. Still worth a call to FFR.
    Nov 2015
    Elverta, CA
    don't sweat the 45 day window. They are very flexible about that
    Simi Valley, CA
    For my Gen 1 kit, the expansion tank was in Box 10F with other cooling system components - radiator fan, hoses, etc.
    HTH,
    Keith
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    It came with my 33.
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
    Prairieville, Louisiana
    It comes with the 33 kit. It’s round, about 3” diameter, and about 1.5 feet long or so. In the box with cooling system stuff. Hoses etc. might be 10F as someone said. Don’t sweat the 45 day thing. They’ve helped me once or twice when i was outside that window. They usually pretty good with customer service.
    '33 Hot Rod
    MK4 Roadster
    Falmouth, MA
    Not in any of the boxes. I've sent a email to ffr asking about it. Is it aluminum or plastic? I've used aluminum cans on other builds and would here but not a plastic can. Thanks for the input.
    If they ship the same part for the hot rod as they do for the roadster, it should look like the one in this picture mounted on the passenger side F panel.
    Village Mills, Texas
    IMG_0046.JPG It should come with the kit.
    It is aluminum.
    '33 Hot Rod
    MK4 Roadster
    Falmouth, MA
    FFR is sending me the missing aluminum reservoir!
  15. Likes HVACMAN liked this post
  16. #15
    Aug 2019
    Fort Lauderdale
    I am building the truck, got my kit Labor Day, got my resivour yesterday along with my headlight shells - what a pleasant surprise - beautiful. Am just starting the plumbing so I hadn't missed it
  17. #16
    Oct 2018
    Just fitting mine, its changed as now shorter (10" long)
    I have 2 entry holes at the bottom and selection of pipe attachments
    1 have one long internal attachment which i amuse is for internal level control ( reaches that level and overflows back out
    A entry hose barb to go back to the radiator outlet
    Not sure what the last little smaller diameter bit is for, doesnt fit any of the thread on the tank..??
    odd little bit
  18. #17
    Grusks, any idea what size that catch can is (the amount of coolant it will hold without overflow)? If I recall, the one that came with my Gen I was 32 oz and barely large enough to hold the overflow from normal expansion on my particular coolant system set-up. I calculated mine to need 30.1 OZ and my coolant system only holds 4.8-gallons. That shorter overflow tank doesn't appear to be any larger in diameter so it may have less capacity than the earlier ones FFR was supplying. You might want to take a close look to see if it will be large enough for your needs before installing it. The theoretical expansion can be calculated.
  19. #18
    Aug 2019
    Arlington, WA
    Quote Originally Posted by Grusks View Post
    odd little bit
    I'm building the truck, my kit delivered last October. I just checked mine and it is almost 16" long. I too have the long tube and one other fitting with a barb, looks like the smaller of the two in your picture. I do not have the other two fittings. So how does this get plumbed? The manual simply states: Attach and route the overflow tank tubing to the radiator overflow nipple.
    Gary
  20. #19
    To use this as a recovery tank, you attach a hose from the radiator overflow to a fitting that draws fluid from the bottom of the tank. The fitting with the extended tube serves two functions: 1) acts as a vent to atmosphere & 2) acts as a tank overflow. Run a hose from this nipple to a place somewhere between the wheels and low (I run mine behind the rear axle) as if the recovery tank pukes you don't want that slippery coolant under a tire.
    On a conventional coolant system (old fashion coolant system like the hot rod & truck), when the coolant gets hot it expands and some will push past the radiator cap and flow into the recovery tank. When the coolant in the radiator and engine cools it will contract and create a negative pressure. The radiator cap has a valve that opens when there is a partial vacuum and that allows ambient pressure to force the coolant from the recovery tank back into the radiator.
  21. #20
    Senior Member nuhale's Avatar
    Jun 2019
    Gurnee, IL
    I have one if you want it.
    MKIV #7275 Acquired June 2019 (2010 partial build), Gen 2 Coyote by Forte w/TK600- PRO 5.0 - McLeod RST twin Clutch-QT Bell, old style IRS, 8.8 3.55 Rear, Gas'n Headers/Pipes, Power Steering, Hydroboost by Forte, Breeze Roll Bar, Heated Seats, 17" halibrand w/ Nitto G2, Maradyne Fan Controller, Paul Proe Vent Kit, Russ Thompson Signal w/ FTP- Received June 2019/First Start April 2020/Go Cart May 2020/Legal September 2020/PAINT BY SPOTLIGHT CUSTOMS JAN 2021
  22. #21
    Oct 2018
    15 FL Oz it holds before overflow
    Im running a coyote if that makes a difference to how much it will push and pull form the tank
    Spence
  23. #22
    Aug 2019
    Arlington, WA
    Thanks Naz, that makes sense and will help when I get to that point.
  24. #23
    Spence
    Without running the calcs I'm fairly confident that is going to be too small. Spence, if you need help sizing one that works PM me and I'll walk you through how to calculate expansion. You will need the total system capacity, the ambient temp you filled it at and the highest operating temp you expect.
  25. #24
    Kingsland, TX
    NAZ would you be willing to share some formulas with everyone here?
  26. #25
    Most everything you wanted to know about coolant but were afraid to ask:
    http://blog.cantonracingproducts.com...e-requirements
    https://www.engineeringtoolbox.com/e...col-d_146.html
    https://www.dow.com/content/dam/dcc/...df?iframe=true
    I’ve simplified the calculation by developing a spreadsheet where I simply add the density and volume info and it automatically spits out the size I need. When I calculate the size of the recover tank I always add a 10% fudge factor, that way I can make sure there is always some reserve volume so air is not drawn into the system.
  27. Thanks TxMike64, JOP33 thanked for this post
    Likes lance corsi liked this post
  28. #26
    Sep 2019
    Houston, TX
    Awesome, thanks for posting.
