Just curious how what type of fasteners you used to mounted your hard brake lines? Rivets, self tapping screws, etc...
Rivets, less chance of snapping heads and rivet can be drilled out
Personally I prefer Rivnuts and stainless steel 10-24 cap head bolts with blue lock-tight and I clean the drill hole with alcohol and paint with a color matched paint pen. But that is just me.
Richard
I drilled and tapped mine using 10-32 screws.
MKIV #8740, Canadian base kit, Picked up Dec. 2015, ‘98 Cobra 4.6 l DOHC, T45 transmission, old style IRS, Art Cuesta dieted harness/Ron Francis chassis harness, go-cart July 2018.
Rivets and P clamps for all of the lines. But I haven't driven mine yet, so who knows. It may fall apart when I do.
?????? threaded attachments, either rivnuts or tapped are fine for service or maintenance items, neither of which apply to brake lines. P clamps and rivets are perfect for this job. Fast and inexpensive.
P clamps with large head 3/16 exploders. I've become a great fan of these things...they pull tight and ain't going anywhere!
https://www.racersspeedshop.com/edge...vets-25ct.html
I like 'em for splash panels too.
