Results 1 to 7 of 7
Thread: Speed Hut Guages
    Sep 2019
    Speed Hut Guages
    Does anyone know how to get a new push button 3.5mm to configure the guages? Speed hut wants $9 for the cable... which I am ok with, but they want $14 in shipping.
    There has to be something on eBay or Amazon that I am not finding.
    X
    Back in the day after a short trip to Radio Shack for a couple bucks you could make them. I've done several. It's just a 1/8-inch stereo mini-plug, a cheap momentary switch, and a couple pieces of shrink sleeving. I forget which two wires they're connecting, but it's easy to buzz out an existing one and find out. If you can scrounge out the parts elsewhere, super easy to make.
    Sep 2019
    Thanks Ed. I’ll do that. I know I’ve got lots of extras.
    Sep 2015
    Hamersville, Ohio
    I also have speedhut gauges and I have a question. As I understand it, the switch you are referencing is only used for gauge setup. Am I correct? If so, do you just disconnect the switch & store it after setup?
    Sep 2015
    Hamersville, Ohio
    Shirley you wouldn’t mount the switch along side the gauge. Shirley?
    The speedo gauge needs the button to reset the trip meter as well as to cycle through the various modes and functions it has. The clock will need to be set any time the battery is disconnected or for time adjustments for daylight savings, etc.
    You don't want to be fumbling around with your hand shoved up behind the dash trying to plug the switch into the back of the gauges. You really need at least two of the switches to have access to the commonly needed/used functions.
    I mounted the switch for the speedo along with the gauge dimmer in a dash support under the dash. I mounted the one for the clock in my glove box.
    Sep 2015
    Hamersville, Ohio
    Thanks Papa. I knew there had to be a good reason for them sending out a switch for each gauge. Just glad I didn’t drill & mount them on the face of my beautiful engine-turned dash panel.
