Results 1 to 12 of 12
Thread: 65 Coupe #658 Headed Toward Completion.
    Jupiter Florida
    Belinda 9-15 2 (1).JPG9-27 Front Quarter View.JPG9-27 Back view.JPG9-27 Front View.JPG
    Headed toward the finish line. Need to install a few fender well panels, the windshield and miscellaneous interior carpeting.
    Then on to registration in Florida.
    Photo's do not do the paint justice. Looks outstanding indoors or out.
  2. Likes Straversi liked this post
    FFR Maven Logan's Avatar
    Huntsville, AL
    Looks awesome! Love the color.
    Any chance you could post more pics and details on the hood vents (louvers/heat extractors)?
    Logan's Gen 3 Coupe-R Build
    Jupiter Florida
    Color is Ford Sterling Grey metallic and Stripe is Ford Silver Grey metallic. Louvers are from Shane at V Raptor Speedworks who also did the one-off vents at the rear.
    I will try to get some close ups tonight when I get home from work.
    Awesome!
    Joe,
    It's a beauty! More pics, please!
    mburger's Avatar
    Punta Gorda FL
    Love it. Like the new side pipes too.
    Mark
    Jupiter Florida
    Insurance 4.jpgInterior Dash.JPGBackup Light Exterior.JPGHatch.JPGDoor Panel 2.JPG
    Engine is a Ford Racing 302, 345 HP. Tremec T5. Lexan Panel between cockpit and hatch area. Backup lights behind rear vents. Paint by Whitby's.
    Man The Inside Looks As Good As The Outside!
    Also, I see you are running an Edelbrock AVS Carb.
    I hope you like yours as much as I like mine.
    Bravo Fellow F5 Family Member, Bravo!
  10. #9
    Aug 2017
    Michigan
    Beautiful!
  11. #10
    Edmonton Alberta
    nicely done with some cool extra touches. I like your door pulls, might "borrow" that idea for mine.
    David W
    Mkll 4874 built in 2004
  12. #11
    Jupiter Florida
    Logan, Here are a couple of close ups of the hood louvers. I used stand offs from McMaster Carr that are epoxied to the underside of the nose. That way you can adjust final height using washers (flush or proud of the surface).
  13. #12
    Huntsville, AL
    JOE A - Thanks for the pics. I like your mounting technique too. They look like TrackSpec hood vents, which is a good thing. Nice products.
