Thanks Thanks:  3
Likes Likes:  3
Results 1 to 22 of 22
Thread: Turn Signals Don’t Work When Headlights On
    Central Lake, MI
    So just yesterday I posted a great video of how I had all my lights working with the RT system and an LED conversion. Turn to today, I get home, want to hear the car rumble after a long day and while it’s running decided to test the lights again...turn signals don’t work. Shut things off, try them again with the engine off works fine. Engine off, headlights on, turn signals don’t work. I have went through every scenario I can think of to narrow it down and come back to somehow the headlights/parking lights are feeding back to the turn signals some how and knocking out the flashers. The electronic flashers do not click when the headlights are on and turn signals are switched on as well. They do click when the headlights are off and left, right, and flashers work as the should. I don’t understand how this is happening when the headlights and turn signals are on different circuits.
    I have the RT turn signal system, LED package from Watson’s Streetworks, and electronic flashers
    Need some help with this one.
    MKIV #9542 Complete Kit, Coyote, IRS - Delivered - 2/19/19, First start - 9/8/19, Go Cart - 9/14/19
    1965 Mustang Convertible 4v 289
    Build Thread HERE
    First thing I'm going to say is start checking all your grounds. Remove lamps one at a time to see if it starts working normal, then go after the ground on the one that changed it.
    Bad / odd grounds can do all sorts of weird stuff. When something doesnt make sense, especially in a simple DC system... go for the grounds.
    I once had a turn signal that was backfeeding into the ignition switch, and every time it flashed, it turned the entire car on & off. You guessed it... bad ground.
  3. Thanks WIS89 thanked for this post
    Likes Aircontroller liked this post
    Agree checking grounds is the first place to look. Went back and watched your video again. Don't see the specific combination you're describing in the video, e.g. turn signals plus headlights at the same time. Did this work before and now doesn't? That would be a pretty big clue IMO. If it never worked, could be ground but also could be something miswired. Agree as well the turn signals and headlights are on completely difference circuits and if all is right shouldn't interact. Bad ground(s) or some kind of backfeeding (via miswire) can do all kinds of strange things though.
    BTW, off topic but in your video don't see the gauge backlighting coming on. Needles yes, but no backlighting. Dimmer turned down? Or not working?
  5. Thanks WIS89 thanked for this post
  6. #4
    "... I once had a turn signal that was backfeeding into the ignition switch, and every time it flashed, it turned the entire car on & off. You guessed it... bad ground."
    Sorry for your trouble, but this is a pretty cool (even if maddening) scenario! This would be the first time I have ever heard of a good excuse NOT to use your turn signals!
    Cruzzz- Boyd and Paul have given you solid advice! Good luck running it down.
    Steve's Stupid Questions Regarding Grounds:
    I've done/created redundant grounds for the headlights, turn signals and brake lights.
    #1 Was This A Good Or Bad Idea?
    #2 My body will be coming off for paint soon so should I keep them or not?
  8. #6
    Steve,
    More "solid" grounds can't hurt.
    At a minimum, the battery (-) needs a good chassis ground. The engine block needs a good ground to the chassis. The RF harness needs a good ground to the chassis.
  9. Thanks GoDadGo thanked for this post
  10. #7
    I also created multiple grounds. I have my lights grounded to chassis at each corner of the car, plus the harness ground. Only problem with too many grounds is the wires and the splices... IOW, do it.
  11. #8
    Feb 2018
    deleted
  12. #9
    Central Lake, MI
    After a lot of testing and also trying a new switch I’ve narrowed it down to current somehow feeding from one input to the other at the LEDs. For example, when I have just the ground and flasher connected to either of the turn signal LEDs I read current coming back out on the other input for the LED (I.e. the running lights). I just switched everything except the headlights back over to the original lights and all works as it should so I don’t think wiring is an issue. I also added grounds at all four corners as suggested.
    Good to know I have a completely working solution but would really like to used the LEDs. Any thoughts?
    Build Thread HERE
  13. #10
    Did you switch the flasher relays over to non-resistive types that are compatible with LEDs? If that doesn't solve it, then you will need to install blocking diodes on the circuits that are back feeding.
    I used these on my turn signals: https://www.amazon.com/1N5824-SCHOTT...4&sr=8-2-fkmr0
  14. #11
    Central Lake, MI
    I installed two of these electronic flashers that came with the package from Watson’s.
    https://www.memotronics.com/2-prong-...2rlnp-bipolar/
    I may need to try the diode’s. Did you just put them on the flasher inputs or running lights as well?
    Build Thread HERE
  15. #12
    I installed them at the output of my turn signal switch, which is an SDC self-cancelling setup.
  16. #13
    Jun 2018
    What is the LED package from Watsons? Are you using the stock Factory Five tail lights or something different?
  17. #14
    Central Lake, MI
    I bought the Basic Cobra LED Upgrade Package. https://watsons-streetworks.com/prod...grade-package/
    Mostly the same package you can get from Breeze. I didn’t realize Breeze sold a set as well.
    Thanks for the picture Papa! I have a couple extra diodes from putting together the Russ Thompson setup but will get a few more and put them in line on all the turn signal and running light leads.
    Build Thread HERE
  18. #15
    If you're wiring looks good, as it does, Led's can be a pain, but they should be simple.
    The electronic flasher units prevent hyper-flashing. If your flash rate is OK, it is OK.
    The diodes prevents a backfeed from one circuit to another. Usually used to separate the turn signal sides so they dont backfeed across the indicator or the switch, powering the opposite side and often leading to 4-way flashers when you engage the TS'es.
    If the running light power wire is disconnected from the rest of the car, ie: there is NO WAY the current is not coming from the dash, then obviously its coming through the LED and that is bad. You could even prove this on the bench.
    LEDs shouldnt do this and its an indication of an internal failure in the circuitry. But one more thing to look at is the way the contacts on the led unit are making in the socket. Make sure theres no little piece of stray solder and that the lamp is aligning correctly. Sometimes the led manufacturers use these elongated contacts, and if they are not aligned perfectly, they can short across and cause exactly what you are seeing.
    An all LED car is very possible and many have done it, including me. Just gotta find that detail thats messing you up.
  19. #16
    I've done two builds with 100% LED lighting. #8674 with the package from Watson's Streetworks. Same as the package from Breeze. Re-sold as I understand. But mine was a few years ago, so no guarantee all the components are exactly the same. My Gen 3 Coupe build is also 100% LED lighting with parts from a variety of sources including Factory Five. Both builds have solid state flashers from Watson's and both builds work perfectly.
    Having said that, I guess I've been lucky. I've worked with several builders who have experienced various issues when switching to LED's. Once any wiring or ground issues were resolved, all traced to backfeeding within the LED devices themselves. If you do a Google search, you'll find this talked about in a number of forums across many interest groups. Typically this problem can be confirmed by replacing the LED's with incandescent one at a time and finding when the problem starts. Sometimes can be traced to a single device, or similar devices. I've heard of guys running incandescents in their front running lights and everything else LED. That seemed to have solved the problem for them. Adding one-way diodes into the offending lines, as described here, is another common solution. The challenge is to find where they're required.
    Whether solid state flashers are installed or not shouldn't be related to this problem. The issue there is LED's don't pull enough current to energize the traditional electromechanical flashers that work via a bi-metal strip and heat. So the failure mode if the flashers aren't changed is the lights don't flash. They go on but won't flash. Guys used to put load resistors in the line to draw enough current to flash the old style flashers. But that defeats one of the advantages of LED which is reduced current. Solid state flashers are a much more elegant solution and in theory should be more durable. They're also sealed, so don't get damaged by moisture or rainwater running down into the fuse panel. Ask me how I know about that.
  20. Likes MSumners liked this post
  21. #17
    I haven't read all the replies so this is just a spitball---would reversed polarity on one or more of the LEDs play into this?
    Central Lake, MI
    Woohooooo! It’s fixed!!!! Bench tested the LEDs and all were good. Went around one by one and replaced the regular bulbs with LEDs starting in the rear and all was good until the last one on the front drivers side turn signal. When I put the LED in and tried the turn signals with the headlights on it just stayed lit and when I tried the turn signal without the headlights it caused the other blinkers to lightly flash. Put a diode on the running light wire for the front drivers turn signal and all is now working as it should.
    Great feeling to get it working. Still not completely sure what is causing the bleed over on that leg of the wiring (I didn’t see it with the regular bulb in) but glad it works regardless.
    Build Thread HERE
  23. Likes Boydster liked this post
  24. #19
    Senior Member dpariso's Avatar
    Beach Park, IL
    Papa,
    What momentary switches did you use?
  25. #20
    Quote Originally Posted by dpariso View Post
    Papa,
    I bought mine from these guys: https://billetautomotivebuttons.com/...7169730052124#
    There are other options available for similar switches. You can search for power window switches as a good starting point.
  26. #21
    Beach Park, IL
    Papa,
    Before your modification, did you have two toggle switches? One for turn signal and one for hazards (like mine in the pic)? If so, can you please help me out on the wiring?
    I still want to keep the hazard switch separate from the turn signals. My goal is to get a new turn signal toggle momentary switch.
  27. #22
    Papa,
    Before adding the SDC controller, I had the standard toggle switches that come with the kit for the turn signals and hazard lights. My hazard switch is mounted under the dash on a dash support. My turn signal toggle switch was in the dash. I opted for a pair of momentary switches, but you could use a double throw momentary toggle switch if you prefer as long as it doesn't latch and returns to center when released. Here is what my final wiring diagram was:
    I tapped the SDC power wire into the RF gray turn signal wire and added a pigtail to feed the two switches. That was the only modification to the RF harness that I had to make. I added the blocking diodes to the SDC leads and then simply plugged in the RF harness turn signal connectors just like they were on the original toggle switch to the two new SDC wires. I removed the flasher relay for the turn signals in the RF fuse panel and put a jumper wire in its place. I made zero modifications to the hazard circuit and it is still exactly how it was per the RF wiring instructions, including the flasher relay in the fuse panel. I can activate the hazards without the key on using the RF hazard circuit just as before. I can also use the SDC unit to activate hazards with the key in the on position if I want to do so. That's simply a built-in feature of the SDC unit that you get for free when you hook up your turn signals. Note that if you do use a single momentary switch, you won't get hazards via the SDC controller unless you do some additional wiring. You would still have the regular hazard circuit, so not a big deal in my mind.
