Results 1 to 5 of 5
Thread: stainless steel brake hose
    Falmouth, MA
    Question stainless steel brake hose
    I have a 1994 cobra rear end with the calipers mounted on the rear of the axle. Does anyone have a source for stainless braided flex lines with the banjo fittings? Lots of sources have the front hoses but I can't find rear hoses.
    Seasoned Citizen NAZ's Avatar
    Having trouble finding what you need in a ss braided hose with a banjo fitting? Consider purchasing banjo to -3AN adapters and you will open up a vast array of brake hoses. Manufacturers such as Earl's make them and for less than $20 you can outfit your rear brakes with adapters that will make selecting hoses easier.
    Kingsland, TX
    Quote Originally Posted by cob427sc View Post
    I replied in the other thread, but look here: https://lmr.com/products/94-04-Musta...ake-Hoses#6229
    Falmouth, MA
    Thanks guys. I'll look into both options.
    Senior Member sethmark's Avatar
    Virginia International Raceway
    I’m not the biggest fan of converting to -AN since it doubles the leak points, but it does basically work fine. If you need custom brake lines there are a ton of sources that will make it you whatever you want. Wickedtrucks.com in Florida has the machine and can make any length any color.
    33 Hot Rod #1133. LS/TKO600
    Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
    Titled 2-28-20
    MkI.IV 2643k
  6. Likes HVACMAN liked this post
