12
82
I took the brake switch out and noticed the tab looked like it was leaning away from the brake pedal, so I just took a big pliers and bent it towards the pedal... Problem solved for the switch.
I cannot find the clutch switch mount yet, still looking. Inventory sheet states that it was put in a different box, but I never checked it off. May have been an oversight on my part during inventory...
I will look over the MC's balance bar, I didn't do anything with those because I thought I read on the forum to just leave it until your ready to bleed the brakes.
25th Anniversary Roadster #12 of 25
Gen 3 Coyote
TKO 600 mid-shift
Car
