Thanks Thanks:  12
Likes Likes:  82
Page 6 of 6 FirstFirst ... 456
Results 201 to 238 of 238
Thread: 25th Anniversary Build
  1. #201
    Senior Member delta0014's Avatar
    Jun 2019
    Atlanta, GA
    Shocks showed up yesterday. They look pretty nice. Will be nice to finally have the suspension all done.
    Couple questions. The springs show #400 and #500 on them, any idea which ones go on the front and rear? I looked through the parts list and directions and none specify. The parts list both say front coil over.
    25th Anniversary Roadster #12 of 25
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  2. #202
    The larger (500 lb.) springs go on the front. Look at your inventory sheets and they will list the front and rear springs with their spring rates.
  3. #203
    Jun 2019
    Atlanta, GA
    The larger (500 lb.) springs go on the front. Look at your inventory sheets and they will list the front and read springs with their spring rates.
    Thanks, the parts list was the first thing I looked at. It lists both springs separately but says "front" for both part numbers.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  4. #204
    Quote Originally Posted by delta0014 View Post
    Build manual says 500# on the front. IRS instructions say 400# for the IRS. Yes, the double adjustable shocks have to be mounted with the body down. Don't recall it mentioned in the Factory Five documentation. Very likely is. But Koni instructions from their website, when I went there to get instructions on how to set them, describes the internal valving in those shocks requires them to be mounted that way. Said won't function properly if mounted upside down.
  5. #205
    Jun 2019
    Atlanta, GA
    It's a roller.. Brakes still need a little adjustment, but it's nice to be able to roll it out of the garage.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  6. Thanks toadster thanked for this post
  7. #206
    Bakersfield, Ca.
    Looks Great!!!
  8. #207
    Folsom, CA
    wow that's great! I hope to be as quick as you! you're rollin at 5-6 months!
    Todd
  9. #208
    Senior Member ydousurf's Avatar
    Feb 2019
    Greality, Colorado
    Awesome! You're making very quick work on your build, impressive! I'm still going through inventory...
    Dj
  10. Likes toadster liked this post
  11. #209
    Jun 2019
    Atlanta, GA
    So, bleeding the brakes...
    I've never actually done it before. I understand the concept but the more I read, I'm not too confident in doing this.
    Bench bleeding the master cylinder. What I read is that it has a bleed screw on it that you run a tube to the reservoir..
    What exactly do I attach a hose too??? I don't see any bleed screws on it.
    And the balance bar.. How do I adjust the long screw rod so the clevis is closer together? They are pretty far apart. I've loosened the top nut on the clevis and the one on the bottom of the picture on the screw rod. I can turn the rod but it doesn't seem to do anything. I don't see in the instructions where it says how to do it... Just says how far apart they should be.
    And the rear calipers have 4 bleed nipples, 2 up and 2 down. Do I bleed all four? Just the top?
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  12. #210
    Bench bleeding the masters:
    1. Make a couple of pieces of tubing with a flared fittings on one end (the tubing needs to be long enough to thread onto the MC where your hard lines are currently attached and have the other end dump into the reservoir(s)).
    2. Disconnect your hard lines from the MCs and attach the tubes you just made.
    3. Leave the hoses attached as you have them.
    4. Fill the reservoir(s) with fluid.
    5. Slowly pump the brake pedal until no bubbles are seen coming out of the ends of the tubes that are dumping back into the reservoir.
    6. One at a time, quickly disconnect each tube from the MC and reattach your hard lines. Do them one at a time.
    Do not pump the pedal again once the MCs have been bled until after you've pressure bled the calipers or are ready to pump bleed each caliper the old fashioned way. Make sure the reservoir never runs dry during the process.
    One the Wilwoods, bleed the bottom first, and then the top. Again, never let the reservoir run dry or your will have to start all over.
    On the balance bar, if you want/need to move the clevises, you have to remove the push rod from the clevis first and then rotate the clevis in the proper direction while holding the pivot rod so that it doesn't spin. Just from the picture, it doesn't appear that yours need to move. Could be the angle. You want them to be pretty much a straight line to the MCs so that the rods are not at an angle from the MCs to the clevises.
  13. Thanks toadster thanked for this post
  14. #211
    Papa beat me... Looks like we disagree on how the Wilwoods are bled though. Doesn't hurt to do the bottom ones I guess. But the top ones are where the air is going to go.
    No bleed screws on the MC’s. You remove the brake line and put a temporary line from there into the top of the reservoir. Pump the brakes until fluid is fully flowing, then replace the brake line.
    The instructions give the spacing required. Two sides together in the .20 - .25 range. To adjust, you need to take one of the MC’s off the clevis and turn the clevis independent of the other. Turning the balance bar will leave your spacing intact, but move the bearing in the middle, affecting the bias. https://www.wilwood.com/PDF/DataSheets/ds252.pdf
    Only the top ones. The calipers have bleeders on both sides so they can be mounted either way. But only bleed from the tops ones as installed. Bleed the outboard bleed screw first, then the inboard.
  15. Likes toadster liked this post
  16. #212
    Jun 2019
    Atlanta, GA
    Thanks guys, you rock.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  17. #213
    Paul -- We don't really disagree. I only did the tops on mine and got perfect results the first time. I only mentioned the bottoms as some have had air trapped. If things are "normal", bleeding the tops only will get-er done. BTW, how many times have we answered this question now?
  18. Likes toadster liked this post
  19. #214
    A lot...
  20. Likes toadster liked this post
  21. #215
    Jun 2019
    Atlanta, GA
    Brakes are bled and feel good.
    Got the E-brake cables hooked up today. Was missing the adapter that connects the cable to the caliper, FFR was nice enough to send them to me, even though I'm way past the inventory cut off. It's tight, handle only does about 2-3 clicks before it's tight.
    Seats are mounted too on the Breeze seat mount. I'm waiting to do the carpet and other interior stuff until it's running.
    It's been 6 months since I ordered the car and 4 months since delivery. Still don't have the fuel tank or dash, although they are saying I should get that next week...
    There's a few minor things I've been putting off.
    Questions...
    ** Sorry kinda long ** But it's all I have left to do besides hooking up the gauges and fuel tank once the rest arrives next week.
    There's a white plug in this picture. What is it for?
    And the yellow taped, vacuum port I believe, it looks like i'm suppose to hook that up to a port in the intake. But there isn't anything on the spectre intake to attach it to.
    Most of these ports I just capped per the instructions that I could see. No heater/AC.
    These two wires that i'm suppose to cut since I believe the coyote controls them. When I cut them, do I just leave them? Cap them? Remove the wires from the fuse panel?
    And for the fan control, I believe this orange wire is suppose to attach to the cooling fan, which it's way to short to reach.
    Instructions say "run the harness with the orange fan wire forward to the fan and connect to the blue wire."
    "Ground the black wire"
    I'm a little lost on how it goes together. Do I just run a wire between the short orange wire and splice it onto the blue wire and connect the blue wire on the cooling fan connection? Or???
    Ground the black wire from the second picture? Or the one on the connection? Or just plug the black ground wire into the connection?
    And on the diagram that shows cutting the fan relay control wire, it says to ground one of the thermostat green wires. I was just gonna ground the Fan Thermo SW wire in the picture below?
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  22. #216
    Responses:
    - white plug in the picture for the Gen 3 Coyote doesn't have anything to plug into. Just leave as is.
    - yellow taped port is the PCV (Positive Crankcase Ventilation) for the LH cylinder bank. Yes, it needs to hook up to your intake. And no, the Spectre intake doesn't have the connection. You need to add it.
    - for your intake connections, mostly OK. You're missing powering the CMCV circuit. I documented here: https://thefactoryfiveforum.com/show...l=1#post351623. Also, with no heater, you're supposed to have a bypass hose between the two heater ports with a restrictor inside. If you bought the Coyote completion kit, it includes the parts necessary for the bypass.
    - for all your wiring questions, looks like you're using the wrong wiring instructions. That's the standard Ron Francis harness manual, right? You need to use the specific Factory Five Coyote installation instructions. It gives the exact instructions. Example: For the cooling fan, you don't use any of the RF circuits or relays. You take the orange Coyote fan wire directly to the positive lead of the cooling fan. Ground the other side, and you're done.
  23. #217
    Jun 2019
    Atlanta, GA
    Here's what I was referencing with the orange cable. It's from the Coyote instructions. So just add some wire to make it long enough and a connector at the end and plug it into the blue side. Run any wire to a ground or do I need to use that ground wire in the previous pics? Do I not use those wires for anything in that previous pic? (blue cooling fan, green thermo, black ground)
    And I guess the coyote instructions doesn't say anything about cutting this red wire, so don't cut it? It says to cut it to make the computer control it, I was assuming that was the Coyote computer.
    I appreciate your responses.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  24. #218
    Right. Connect the Coyote cooling fan wire to the blue wire on the cooling fan. You'll need to extend the wire as discussed. The black ground wire on the fan motor can go to any existing ground wire (e.g. in the RF front harness, which is what I do) or you can clean a spot on the chassis and attach it directly in the area of the cooling fan. The RF blue cooling fan and green thermo are not used. You could use the black ground but doesn't have to be that specific one. Ground is ground wherever. You don't need to cut anything on the RF cooling fan panel. Wired direct that circuit isn't used for the cooling fan. 100% controlled and powered by the Coyote system.
  25. #219
    Jun 2019
    Atlanta, GA
    Awesome, thanks.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  26. #220
    Jun 2019
    Atlanta, GA
    Carbon fiber dashboard has arrived. It looks really nice.
    Fedex says the fuel tank will be here tomorrow and that will be the last of the POL parts.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  27. #221
    Feb 2020
    Chicago
    looks great man.
  28. #222
    Jun 2019
    Atlanta, GA
    Still can’t figure out the fuel pump wiring. The green wire is getting no power. The fuel pump works if I put the wires I was suppose to cut back together. I replaced the relay just in case but no help...
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  29. #223
    Responded in your separate thread with this question. Maybe it's just semantics, but the Coyote green fuel pump wire doesn't "get power." It outputs +12V from the fuel pump when commanded by the PCM. So when you turn the key on, you should be able to measure +12V on that wire. If there's no voltage on the wire, the PCM isn't commanding it. Or a fuse in the PDB as I mentioned.
  30. #224
    Jun 2019
    Atlanta, GA
    So, is there a way to know if it’s the computer?
    I hooked the wires up so the fuel pump runs continuously and tried turning it over. Never fired once.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  31. #225
    Jun 2019
    Atlanta, GA
    I checked every single fuse, none were bad.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  32. #226
    Folsom, CA
    so weird I got my springs, and everything else but the shock bodies
    Todd
  33. #227
    Jun 2019
    Atlanta, GA
    So, no idea exactly how I got it to work. After talking to the Ford Tech, he suggested sending in the computer to get looked at.
    As a last ditch effort I went through and disconnected everything on the coyote wiring, computer, battery, grounds and re-connected everything one last time. Michael Everson commented on Facebook that the first start took a long crank to get it going. After I connected everything back up, still wasn't hearing the fuel pump but I cranked it over for what seemed like a long time. And it finally fired. I've started it a few times and starts good. I got it running last night, this morning it cranked over longer then I think it should but I do hear the fuel pump when I turn the key on now.
    Cooling fan works, oil psi, water temp, volts, gas gauge work but the Oil temp gauge didn't seem to be working.
    Small coolant leak where I put the oil psi/water temp sensors in the engine but otherwise everything seemed good.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  34. Likes ydousurf, PeteMeindl liked this post
  35. #228
    Feb 2019
    Greality, Colorado
    Awesome! Nice work in getting to the (FSS - First Start Stage) this quickly. c[CHEERS!] - Here's to the final push to get your dream on the road!
    Dj
  36. #229
    May 2018
    Park City, Utah, USA
    Nice! That's great news - definitely one of the best feelings of the build to get that first start!
  37. #230
    Congrats! Glad to hear she's running.
  38. #231
    Strange. But good. These things do go through a learning process. Hard to imagine that it has to learn basic stuff like "turn the fuel pump and injectors on." Not going to argue with success. But keep an eye on it. Both my Coyote's (Gen 2 and Gen 3) start almost instantly. Very little cranking required.
  39. Likes jiriza84641 liked this post
  40. #232
    Jun 2019
    Atlanta, GA
    Took the car out around the block today. Everything felt good, drove good. Only got up to second gear though. Gave the kids a ride, they loved it.
    Interior is almost done. Still a little more carpet and finish the glovebox. But I like it.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  41. Likes PeteMeindl liked this post
  42. #233
    Jun 2019
    Atlanta, GA
    The car is still taking a long time to start for the first start of the day.
    After the first start, it starts pretty good again.
    Guessing something with the fuel pump, but once it's running it runs great.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  43. #234
    What temp. range does your gauge start to read at?
    Oil temps take a long time to register on the gauge, and that's while out cruising around, not just idling in the driveway. It probably works fine, you just haven't got it hot enough yet.
  44. #235
    Jun 2019
    Atlanta, GA
    I'm actually gonna remove the Oil temp gauge and order a clock that matches. I really dont need a oil temp gauge.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  45. #236
    Feb 2020
    Chicago
    Dash Q?
    Where did you get the carbon fiber dash?
  46. #237
    Folsom, CA
    Quote Originally Posted by jiriza84641 View Post
    comes with the 25th anniversary car
    Todd
  47. #238
    Jun 2019
    Atlanta, GA
    Yes, the carbon fiber dash and the seats were part of the 25th anniversary edition. I'd be surprised if FFR didn't offer the carbon fiber dash in the future as an upgrade. I think it looks great.
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
