Power Steering Pump installation
I just installed the KRC power steering kit onto my Coyote engine and i have a slight interference with a boss on the cylinder head (see red circle on photo). I've rotated the pump as far as it can go and the belt is tight. It appears that the fluid reservoir is kinda clocked to the left a bit However I think this may be normal (see second photo). I followed the instructions and it seems the only adjustment that can be made is rotating the pump on the bracket. Are there any additional adjustments I can make? The only way I can think of to straighten the pump and reservoir is to get a longer belt.
Thanks for any thoughts on this,
Tim
