Results 1 to 7 of 7
Thread: Gen 3 Coupe Coyote Computer and Power Distribution Box location
    Member Hoschton Hotrod Haus's Avatar
    Sep 2019
    Hoschton, GA
    Hey Guys,
    I am new to the forum and deep into the construction of a Gen 3 Coupe with a Gen 2 Coyote.
    I would like to see where you guys mounted the Ford Performance Power Distribution Box and the Engine Computer.
    I will be installing the FFR A/C so It limits the locations.
    I am Thinking about mounting the Power Box on the front inside of the Passenger Footbox and the Computer on the back side of the cooling duct in front of the engine.
    Your Suggestions and pictures would be great,
    My Gen 3 Coupe build thread shows where I mounted the components you're asking about. Link in my sig line below. It's a Gen 3 Coyote (2018+) but the components are similar to the Gen 2 Coyote which I previously installed in a Roadster. For the Coupe, I put the PDB on the firewall toward the driver side. Footbox might a little tight IMO. For the PCM, mine is on top of the PS. Functional, but not very elegant looking. But the Gen 3 PCM is somewhat larger than the Gen 2, and I prefer a Mustang style radiator expansion tank. So that limits the space you're talking about for the PCM. But I know of at least one build that did something similar as you're describing with a Gen 2 Coyote. Mine also has heat and A/C. Placement of the components you're asking about is important, of course. But IMO it's important to take into account also harness runs, power connections, what goes behind the dash, etc. I mocked everything up with the engine sitting on the mounts before finalizing anything. Good luck.
    Sep 2019
    Hoschton, GA
    Thanks Edward,
    I would like to see where some of you other guys mounted the box and computer.
    Bourne-Cape Cod, MA
    Quote Originally Posted by Hoschton Hotrod Haus View Post
    Thanks Edward,
    I am building one now for SEMA- box is behind the dash, computer is mounted to the chassis behind the motor. This car has a/c as well. The ac goes in the passengers footwell
    There is plenty of room behind the dash for the PDB .
    FFinisher/AKA RE63
    Atlanta, GA
    I centered the computer in the firewall with the PDB mounted in the engine bay below it. I was able to modify the harness so that the excess harness is coiled and hung above the trans out of sight. I have a little interference with the rear of the computer and the forward part of the headlight switch, but it is doable.
    Gen 3 Coupe, Gen 2 Coyote, Wilwoods, IRS, Power Steering, AC JDAVIS500 Build Thread
    I'll stay away from any further recommendations, since what I've done in two Coyote builds is explained in my build threads and summarized above. And certainly there are multiple ways to do this that work just fine. But just keep in mind, (1) the PDB does have user serviceable parts inside (fuses, relays, etc.) so needs to be accessible, (2) the PCM should also IMO be at least reasonably accessible and removable. If it ever needs to be re-flashed by Ford (has happened to me several times across the two builds) it has to be sent back to them. They turn it around pretty fast, usually in a day. But it has to be loose. My main advice, which I made in another post the OP of this thread, is mock up everything before finalizing your layout.
    Jan 2019
    Richland, WA
    I mounted my PDB in the same place as edwardb, but ended up mounting my computer differently: https://thefactoryfiveforum.com/show...266#post375266
