Nearly 3 years in the works and got the body set on today.
Everything went well. Friend and I with a swing arm car lift, got it in place.
I have a few questions that I will keep brief and to the point.
It looks like the body needs to move forward about 3/4". The back inside the trunk is bottomed out on the alum shelf and the rear of the vertical sides.
Is it standard to trim and reinstall the bulb seal?
The holes in the bottom of the body that screw into the frame are also about 3/4" to the rear of the frame holes.
Are these holes, drilled from FFR, where the body needs to be?
The bulb seal on the trunk sides top edge do not seal against the body.
It looks like this will allow dust to enter the trunk.
What is the fix?
The expanding foam on the foot boxes is not sealing against the body.
I have read about using the pool noodles to fill in the gap.
Will the expanding foam grow to fill the gap?
The body lip that hangs over the dash is touching the vinyl pad on the dash.
If I move the body forward 3/4" the body lip will be riding the vinyl very tightly.
I have not read about trimming this area at any time, but could have missed it.
The dash panel exposure to the body lip looks good. The dash is held in place with industrial velcro, which is about 3/16 to 1/4" total thickness.
Do I need to trim the body?
Thanks for any help in resolving these issues.
