Results 1 to 5 of 5
Thread: Bigger tanks
    Feb 2018
    Bigger tanks
    all right I'm researching more on this type 65, the fuel tank capacity of somewhat small at 15 gallons. I don't think that capacities is a port how far I want to drive without constantly stopping by a drinking hole and every hour. I know it's an exaggeration but anyhow... I saw that one of the sponsors here has a 22 gallon tank so my question is are there any other manufacturers out there to have a bolt in higher capacity fuel tank? Or is it I'm just have to go custom?
    Maricopa AZ
    Fuelsafe has a 22 gallon cell. If you have anything close to a reasonable engine you will get at least 15mpg cruising. At 14.6 gallons that makes around 250 miles. By that time you are ready for a leg stretch.
    Feb 2018
    Thanks Gordon.
    I love slightly a bigger tank than 22
    Maricopa AZ
    I have done a 32 for an endurance race car but it takes up the entire back of the car leaving little to no room for anything else.
    Senior Member narkosys's Avatar
    Boyd welding makes tanks for Factory Fives. Here are tanks for the Roadster which are direct fit for the Type 65 as they both use the same Mustang tank. Give them a call if you need it for an injected engine as I remember them making them before.
  6. Thanks GoDadGo thanked for this post
