Results 1 to 10 of 10
Thread: 818C Door Locks
    Member LearningCurve's Avatar
    Haymarket, VA
    818C Door Locks
    Anyone had any luck with the driver side door lock on the 818C?. I can't seem to get enough rotation on the lock to trigger the lock/unlock mechanism. There just seems to be too much flex on the "L" bracket and the bracket attached directly to the lock. I also just realized that I have that bracket installed upside down compared to the photo in the manual. I am not sure if this would make much of a difference as the rotation should still be the same.
    If anyone has any tips for this please let me know. I can't find much of the topic when searching.
    https://photos.app.goo.gl/6LhtN5wHyCxu9qU96
    818C - #458 | Delivered-11/16/16 | First Start/Go Kart-8/24/18 |
    Daily: 2004 WRX
    Weekend: 2012 S4
    Jun 2017
    Had the same issue.. I just made my own bracket and it worked a LOT better
    Haymarket, VA
    Quote Originally Posted by kcarlasc View Post
    Do you by chance have any photos of yours setup? I am still struggling with getting this to work properly. What I think would work is if I had a bracket that attached to the key lock/unlock mechanism that had a much larger engagement area. With the provided bracket, there is a large area where the key lock/unlock mechanism just spins freely without actually engaging with the bracket. I tried to fabricate my own but was not able to due to the tight tolerances needed.
    https://photos.app.goo.gl/9QPXrAztC9Yd4D2k6
    Daily: 2004 WRX
    Weekend: 2012 S4
    Senior Member AZPete's Avatar
    I can't help with your key lock question because I used different door handles, but if you saved the donor door lock actuators you have a work-around. See this thread, post #21:
    https://thefactoryfiveforum.com/show...nished-I-think
    Jun 2017
    Quote Originally Posted by LearningCurve View Post
    Sorry I don't.. I just used a piece of straight piece of aluminum and it work out fine.. Much better than the L shaped one..
  6. Thanks FFRWRX thanked for this post
    Baldwinsville, NY
    I used the provided "L" piece but had to make multiple bends and twist to make the bracket fit and provide clearance to the glass. I would not finalize anything until the glass is installed. I also installed a spring on the bolt between the top "L" piece and the bottom of the lock mechanism to prevent it from rattling. Unfortunately I was not able to find pictures. I remember experimenting with multiple bolt lengths as well. Hope this helps.
    Sep 2015
    Hamersville, Ohio
    Door poppers! No outside handles or locks!
    Apr 2014
    Quote Originally Posted by lance corsi View Post
    thats 100% what I did. Push button opener inside and used a door lock controller to pop the doors outside. with manual releases ran just incase.
  10. #9
    Feb 2019
    Houston, TX
    Quote Originally Posted by Newkitguy View Post
    Do you have a link to details? This is on my list of things to work on in the spring.
  11. #10
    Apr 2014
    AJ i don't have a link as I don't have a build on the forum. but if you have any questions shoot em over and i'll help where i can.
