Thread: SBC Blueprint 383 700r4 install
    Jan 2018
    Mt. Pleasant, Tx
    What are the measurements to cut the spacer tube to move engine back to clear steering rack.
    Depends on your drive set-up. Run a single v-belt drive and a short water pump and no need to move the engine to the rear. Try to run a roots blower drive and you'll likely be modifying the firewall to make room for a serious engine setback. Anything in between those two extreme examples and I suggest you do the measurements yourself and not rely on what someone else has unless they have the exact same set-up. And don't forget that moving the engine changes the driveshaft length required.
    I moved mine a bit over an inch and I can fit a long water pump lower single v-belt pulley and still have clearance between the rack and have sufficient clearance from the back of the engine to the firewall. But I measured the space available and the space my engine set-up needed to determine the engine setback for my specific combination. Your mileage may vary.
    Jan 2018
    Mt. Pleasant, Tx
    Thanks Naz. Installed motor and trans today. Looks like all worked out other than I was shipped the wrong trans mount.
    Good to hear, post a photo when you can. Have fun with your build.
    Feb 2018
    Grapevine, Texas USA
    I did the same as Naz. 1". Worked perfect. I live in Fort Worth. If you are in the DFW area, stop by and I'll show you my build. I have it running on stands. Have not driven it yet.
    Larry
    FFR Hot Rod #1106
