Results 1 to 2 of 2
Thread: Wipers 33 coupe
    Oct 2019
    Wipers 33 coupe
    Wipers. 33 coupe , vacuum or mechanical style?
    Seasoned Citizen NAZ's Avatar
    If you put vacuum wipers in your FFR 33HR I want to see a Flathead V-8 under the hood and painted wire wheels with skinnies mounted on them.
    Not sure why anyone would want to drive one of these cars in the rain but if you do, invest in a top end set that will cover both side of the windshield and powered by electrickery, not suction. I needed a single one-speed wiper to get through my MVD (in AZ it's MVD not DMV) vehicle inspection and the inspector never actually checked to see if it worked. Bought the cheapest one Speedway Motors had and right after the inspection I removed it and stored it for the next project. I'd rather be on a motorcycle in the rain than get caught in a rain storm with my hot rod.
