So, I set the body back on after go carting, started fitting the body to firewall, and set the 45.5 inch cockpit dimension. I set the trunk aluminum in and the first thing I found was my tail pipes were too high. I had to drop those down almost 1.5 inches. The second thing I noticed is two cracks in the body near the firewall on the driver side. At first I thought they were scratches but you can rub your finger across them and feel the difference in elevation. I have no experience with fiberglass repair. Should I drill a hole on each end to stop the crack from expanding? Then
grind them out and fill with mat and resin? Then gel coat on top?IMG_0183.JPGIMG_0184.JPG
