Likes Likes:  2
Thread: Additional Trunk Space found
    Oct 2017
    Added some additional trunk space in addition to the Russ Thompson dropped trunk. Note that this is a 2015+ IRS car.
    MK4 #9191, Gen 3 Coyote, T56, 2015+ IRS, ABS, 12.88 Wilwood's, FFR Tubular Front LCA's, FFR Spindles
    Senior Member Garage Guy's Avatar
    Jan 2019
    Detroit MI
    I think I might have to do this to mine thanks for sharing
    On a roll Al_C's Avatar
    Wheaton, IL
    Great idea! The only problem is that's where I put my battery. I did find, however, that with a little massaging of cardboard, you can fit an entire case of wine in the Russ Thompson drop box... (Costco run...)
  4. Likes GTBradley, Jetfuel liked this post
    Every little bit helps. I did the common drop for the left 2/3 of the tank and left the bars in place. I can't get any large things in there but I cram in a whole lot of smaller items. You will find uses for this because that area is another that would be nice to be a bit taller.
