Thread: Fastrax no lip adapters needed with 17" halibrand style rims?
    Senior Member Dagwoods's Avatar
    Lavon, TX
    I'm about to order a fastrax 91000 alignment tool and wanted to know if the SPC 91030 FasTrax No Lip Adapter are needed for my 17" halibrand style rims. Would rather not spend the extra $70ish dollars, but if they are needed will pick them up at the same time.
    Thanks.
    Mk IV base kit #9273 Delivered 1/29/2018
    3-link Moser 8.8 3.55
    TKO 600
    427w by Fordstrokers w/Holly sniper efi/hyperspark distro and ignition
    RJD's Avatar
    Northern Virginia
    I did not use the adapters. However, I did use a couple of large rubber bands to secure the fastrax 9100 to my wheels. Worked great.
    Lavon, TX
    Awesome tip. Thanks. No issue with the tool flexing?
    TKO 600
    RJD's Avatar
    Northern Virginia
    Quote Originally Posted by Dagwoods View Post
    None.
    It was fine for setting camber and caster. I didn't care for the toe-in adapters for the fastrax though, and went with automotive toe plates by Zackman Scientific to set toe. Ordered them from Amazon. Comes with two plates and two tape measures. Easy to use.
