Results 1 to 2 of 2
Thread: Another Exhaust cutout Question
Hybrid View
    Senior Member brewha's Avatar
    Aug 2013
    Somers, Ct
    I’m in the process of prepping the body to get it to a painter. I was pretty happy with the exhaust cutouts and drove the car for awhile without thinking about changing it. When I decided to start the body work I took the body off the car so dust would not be an issue getting into the interior or engine compartment
    To remove the body, I had to take the exhaust off as there wasn’t enough clearance when lifting the body near the exhaust cutouts. I started thinking that I’ve had the body on and off at least 4 times and each time I had to remove and re attach the exhaust pipes.
    Do I have my exhaust cutouts too tight? Does anybody not have this issue? If I widen the cutouts will the body lift off with the exhaust on?
    Mark4 - 331 Stroker - Fitech 600 -TKO600 - Moser 3.55
    Alliston, Ontario, Canada
    You’re all good. Pipes have to come off to remove or install body. Body has to move forward to come off. Taking front wheels off helps a ton too.
    2017 FFR MK4 9026, 3 Link, 15" FFR halibrands, cooper cobra tires, '88 302/5.0, GT40 Y303 heads, Performer RPM intake Manifold, Holley 650 DP Carb, Pertronix distributor, T5Z spec built transmission, 3.73 rear end. Ordered Nov 2016, picked up at FFR Feb 2017, first start July 2017, Legal on the road May 2018, still in Gelcoat.
