Results 1 to 2 of 2
Thread: for sale aluminum 3 pulley set.For SB Ford
    Senior Member gtaroger's Avatar
    Trenton Mi
    I have a set of pulleys that are the v grove type. The lower pulley has a three bolt pattern. It will fit the 302 and 351 windsor motor.The pulleys are in nice shape.I install power steering and switched to the two grove pulley set.$75.00 or best offer plus ride. Roger
    Super Moderator
    Ray's Avatar
    La Mesa, California
    photo?
