0
0
Seasoned Citizen
I actually calculated my coolant expansion to determine the size of recovery tank at 30.1oz to handle the expected expansion but I added a 10% safety margin so theoretically I should need <33 oz. So far that has worked, but your mileage may vary.
Assumptions: 4.5-gallon total capacity, 50% coolant, filled at 60-deg, max operating temp 220-deg.
33 Hot Rod Super Pro Drag Racer Build:
33 HR NHRA Cert Roll Cage Build
