Results 1 to 6 of 6
Thread: Coyote temp control
    Jun 2019
    Whitehouse TX
    Coyote temp control
    What sensor do we use for the fan temp control on the Coyt? Two came with the kit.
    Zach
    Normally won't use that sensor. Standard practice is to have the Coyote system control the fan. The Factory Five Coyote installation instructions along with the Ford Performance instructions give this and all the other details for your installation.
    Jun 2019
    Whitehouse TX
    Thanks again
    Jun 2019
    Whitehouse TX
    Edward,
    Happy New Year.
    What do we do with the oil temp, oil pressure and water temp wires from the chassis harness?
    Zach
    Quote Originally Posted by sperger72 View Post
    Edward,
    Happy New Year.
    Zach
    Thanks. Happy New Year to you as well. I think your question was answered in the other thread you have going. You mention Vintage (Speedhut) gauges. You can use the cables they provide and go directly to the RF harness on the gauges. Or you can splice the Speedhut cables to those wires so the gauge wiring goes through the dash harness connectors. Then wire the gauges to the dash harness. Either way.
    Jun 2019
    Whitehouse TX
    Thank you
