Shifter Handle
My shifter sheared off today while driving. Fortunately, was able to coast into a garage and borrowed a piece of pipe to at least get me home. This was a non-functional reverse lockout part and the shifter is now trashed. My question is, anybody have a good source for the traditional angled shifter? I could order from ********** and normally would as I have patience, but there are only a few more weeks left in the driving season, and um... well, ********** response time...enough said. Any other sources? I like the angled look and I believe FFR only provides the straight one.
MK IV Roadster #7999
Ford Racing 427x; QF 670 Carb; TKO 600; 3.31 Rear End; 3-link; 17” Halibrand Replicas (9” front, 10.5” rear), Khumo Ecstas (245 front, 315 rear), EPAS Power Steering; Power Brakes; 8/1/19 - Legal in gelcoat!; 12/1/20 - Paint & bodywork in progress! Silver, no black, no red, wait now silver....
Why not take it to a shop and get it welded. The weld should end up below the bellows and should hold fine until you get a new one.
F5R #7841: Anniversary Edition MK4, Ford Racing 427, Edelbrock EFI, Gas-N Pipes, Stainless Headers, TKO600, 3.31 Moser 3-Link, 17" Halibrands
CDXXVII
X2. It should be far enough under the boot. I'd get it re-welded and move on.
That looks like the shifter that Finish Line sells and I recall one other builder had his snap as well. I think Finish Line may have sent him a new one if I remember correctly. Seems they got a batch where the welds didn't penetrate very well.
Edit: After looking at it a bit closer, the it's different than the Finish Line one. Theirs's has a square bar stock end where the bolts go through instead of the flat stock. I agree, get it welded back together and call it good.
Seasoned Citizen
No problem welding it. If it was mine, I'd weld it and use it as long as I needed it.
33 Hot Rod Super Pro Drag Racer Build:
33 HR NHRA Cert Roll Cage Build
FFR one is angled. Do you have the one that came with your kit?
2017 FFR MK4 9026, 3 Link, 15" FFR halibrands, cooper cobra tires, '88 302/5.0, GT40 Y303 heads, Performer RPM intake Manifold, Holley 650 DP Carb, Pertronix distributor, T5Z spec built transmission, 3.73 rear end. Ordered Nov 2016, picked up at FFR Feb 2017, first start July 2017, Legal on the road May 2018, still in Gelcoat.
I agree with the others, get it welded to finish out this season and find a new one this winter !
Walt
FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
Thanks all, I'll try to track down a welder later this week to get me through the season (one more reason for me to take up welding!). I'll probably order another one from ********** or FFR as well without worrying about a rush (it seems FFR is on backorder right now as well).
MURD - Thanks, I missed that the FFR one is in fact angled too. I have a base kit so my original came from **********.
Base kits come with them I believe. I also bought a base kit and I don’t think mine was part of an option/package.
Administrator
CFranks,
I have a new FFR one I can send you to get you through the end of the season. Just pay shipping.
Henry
65 Cobra Dude
CFranks,
Henry
That's awesome, thanks! PM Sent
Administrator
Replied to PM. I'll ship it out tomorrow. I just ask that you "pay it forward!"
Henry
65 Cobra Dude
Henry
Will do. At this point, due to all the generosity on these forums, my “pay it forward” tab is essentially an entire cobra!
