Thanks Thanks:  11
Likes Likes:  7
Results 1 to 13 of 13
Thread: Brake size input wanted
    Senior Member Traveller's Avatar
    Jul 2019
    Grand Rapids, MI
    I am now at the point of installing brakes and am second guessing myself and would appreciate opinions from the group.
    I have the complete kit with IRS and manual brakes. I chose to NOT buy the wilwood upgraded brakes, so I have the GT 11" fronts and the 13" rears, all on 18" halibrands.
    I ordered the standard brakes based on the the car being a road cruiser (although with some spirited driving) and little to no expected track time.
    I welcome your feedback on 1) performance-wise do you feel this setup will perform well? and 2) will the relatively small and unequal sized rotors look silly in the 18" wheels?
    -Jason
    MK4 Complete Kit #9673 | Ordered: 08/07/2019 | Pickup: 08/24/2019
    Gen 2 Coyote, TKO600, IRS, Power Steering, 18" Halibrands, Kirkey Vintage Race Seats, Gas-N Headers and Pipes
    Build Thread: https://thefactoryfiveforum.com/show...IRS-Build-9673
    We used that same set up on a 427 MK4 with no issues. Though it does look different. You could just upgrade the fronts to Wilwood's. See build thread below.
    http://thefactoryfiveforum.com/showt...4-build-thread
  3. Thanks Traveller thanked for this post
    The brakes you have will be fine performance wise, especially for a 99% street beast. It's a light vehicle, and they won't be subject to constant heavy use, as a race car would.
  5. Thanks Traveller thanked for this post
  6. #4
    Jax Beach, FL
    Correct brake size = Big 'uns.
  7. Likes Traveller liked this post
  8. #5
    Edmonton Alberta
    it really is cosmetic on a street car. My Mkll still has 93 Mustang brakes, 11 inch fronts and 9 inch drums on the back and it stops just fine. The new Coupe I went with Wilwoods stops fine and looks better.
    Just remember we like to help you spend $$$
    David W
    Mkll 4874 built in 2004
  9. Thanks Traveller thanked for this post
    Likes RBachman liked this post
  10. #6
    Jax Beach, FL
    I'll argue that even a street car can't stop too fast. I'll bet your coupe stops in a shorter distance than your MKII. Far from cosmetic if someone pulls out in front of you. One more foot can be one foot too much.
    I am a fan of Wilwoods on these cars.
  11. Thanks Traveller thanked for this post
  12. #7
    Brakes are not as much a limiting factor, tire adhesion is. You can have the most massive brakes in the world, and they aren't worth a dime if you have lousy tires.
  13. Likes Traveller liked this post
  14. #8
    What about upgrading to the 13" Cobra/Mach-1 front set up?
    That way you can get pads and rotors nearly anywhere.
    All Ford Brakes May Be The Easiest Options!
    https://lmr.com/item/SVE-2300CB-S/mu...4-c-tek-rotors
    PS:.. Then stuff a Chevy in it to make it go.
  15. Thanks Traveller thanked for this post
  16. #9
    "The I.E." SoCal
    I have to agree with Rich. I've watched a few brake threads on the forum here lately and just about cringe everytime I hear someone say "you want to lock-up blah, blah, blah brakes first". Really???? I don't want to lock up ANY brakes first or at all. If you're locking brakes, you're no longer braking, you're sliding out of control. Stock brakes are fine, especially with the 2002+ Mustang 2 piston calipers in front. Want more grip? Go for a more aggressive pad, corner-weight the car and learn how to threshold brake.
    __________________________
  17. Thanks Traveller, BLUE KNIGHT thanked for this post
    Likes Traveller, BLUE KNIGHT liked this post
  18. #10
    You will be fine. That is almost exactly what I have. In fact my fronts may be just a tad smaller because they have the older single piston calipers.
  19. Thanks Traveller thanked for this post
  20. #11
    Jul 2019
    Grand Rapids, MI
    Thank you everyone. I am going to stick with what I have. In Michigan, there are many non-driving months each year so plenty of opportunity to upgrade in the future if desired.
    -Jason
  21. #12
    Jax Beach, FL
    AMEN, brother!
    I am with you 110 %.
    I was going to add ...."and you need good tires". But I thought people might be tired of hearing me say it.
  22. Thanks BLUE KNIGHT thanked for this post
    Likes BLUE KNIGHT liked this post
  23. #13
    Lost Wages, Nevada
    I have to agree with what Frank said above - if you are locked, you are out of control.
    That being said, I run the 13", dual piston conversion on the front of my MK-II - no power assist and can stop hard enough to stand the car on it's nose (actually just a figure of speech, made by [old] car guys that want to "express" just how hard it stops).
    11.65" in the rear, single piston. Car is corner weighted and I can stand on the pedal and lock all four, but have learned to "throttle" the brakes for maximum grip.
    Doc
  24. Thanks Traveller, BLUE KNIGHT thanked for this post
