Likes Likes:  4
Results 1 to 11 of 11
Thread: Alternative license plate mounting
    Junior Member denn1s48's Avatar
    Jan 2019
    Grass Lake, Mi
    I've been trying to think of how to move the bracket up if FF5 doesn't offer the new trunk lid and had just about decided to try building up my trunk with fiberglass but since I've never worked with it and have done quite a bit of metal work I thought I would try that first. Here's what I came up with using some scrap stainless steel I had. Needs more work on the polish but I was wondering what others thought about this approach. I guess you could make it out of steel or aluminum and paint to match the body color but would like some feedback. It raises the bracket 1 1/2" so you still have to watch out for the pinch between the license plate and the trunk latch handle but every little bit in height increases the front to back quite a bit.
    Purchased partly completed #7923 2/9/2019
    Mach 1 4.6L, 3650 Tremec, chrome dual roll bars,
    Inspected & applied for title 9/5/2019, finally received VIN sticker 12/11/19.
    Added: Heater/defrost, electric assist power steering, heated seats, Drummer Mike ceramic coated heat shields ( highly recommend them! )
    custom running/fog lights in oil cooler opening
  2. Thanks Aircontroller thanked for this post
    Likes Aircontroller, ydousurf, RBachman liked this post
    RJD's Avatar
    Northern Virginia
    I like it. Well done!
    North CT
    Nice job on piece
    Watch this video https://youtu.be/Ok9W_Dzao3M?t=601
    Senior Member Joel Hauser's Avatar
    Albany NY
    I just trimmed my license plate to fit. It passed inspection, and I've never had any complaints from the police.
    Nice Period Correct Looking Solution!
    Here is a solution that might work too for those of us who can't weld very well and tend to make Volcanic Bird Poop instead:
    https://www.jegs.com/i/Billet+Specia...AaAr4TEALw_wcB
    You can see my solution at the beginning of the video shown below:
    https://youtu.be/_3sLamdkIFg
    Keep Wrenching & Keep Thinking Outside Of The Box Because That's What Our Hobby Is All About!
    So. Bay (So. Calif.)
    I'm not sure if you have paint or gelcoat, but I did the Kleiner mod and had Bat build up the mount pad during the body work. See post 22, bullet #7. https://thefactoryfiveforum.com/show...d-Circumstance
    Raleigh NC, OIB NC
    Work is nice but I took a simpler approach. Notched & insulated the plate & bonded it to the FFR cross piece as the screw holes no longer lined up. No issues with inspection or roving police cars.
    Kevin
    MKIV #8234
  9. #8
    "The I.E." SoCal
    How can I say this with out hurting anyone's feeling?
    Looks like it was a lot of work.
    __________________________
  10. #9
    Jan 2019
    Grass Lake, Mi
    Thanks for the feedback from everyone and no hurt feelings, it was a lot of work, but being retired gives me a lot of time & I hate daytime tv, actually most tv period. If I ever get the VIN & title there won't be as much time to work.
  11. Likes BEAR-AvHistory liked this post
  12. #10
    Senior Member ydousurf's Avatar
    Feb 2019
    Greality, Colorado
    Genius, denn1s48! Way to think outside the box for a solution that works very well. Very nice!
    Dj
  13. #11
    I like it. I'd much rather work in metal than in FG and body filler so I'd do your fix for sure.
