Post Thanks / Like - 2 Thanks, 1 Likes
Seasoned Citizen
The stuff works great! Used it on my hot rod but painted it rattle can aluminum and from 8-feet you can't tell it's there. The grill shell holds it in place without any other attachments (at least up to 140 MPH so far). Slides out to clean.
33 Hot Rod Super Pro Drag Racer Build:
33 HR NHRA Cert Roll Cage Build
Very nice! and an easy way to protect the radiator
Senior Builder
I really like the clean look with the both Everson’s panel and the Nomex Honeycomb painted black! It’s great when mods like this enhance function, appearance and durability!
Seattle area; MK4 kit received 5/18; Build completed 3/20; Gen 2 Coyote, TKO600; IRS; Wilwood brakes; PS; PB; Gas-N sidepipes; Vinyl Dash with glovebox; Heater/Defroster; Premium Soft Top
i did the same as Kevin!! I like the "black hole" effect!
Chuck Krueger
MK4 Kit - Picked up 4/5/14, Complete Kit, 3-Link, Wilwood upgrade, Coyote, TKO 500, First Start 7/25/15
2000 C5
2003 C5 Z06
2007 C5 Z06
Nice looking. I discovered that aluminum z bar holds this down at the top and bottom nicely. Plus, it allows easy removal
https://thefactoryfiveforum.com/show...pproved/page10
25th Anniversary #9772
I got this setup, the nomex and a z-bar to mount, I assume I have to wait until the body and any radiator shrouding is mounted - correct?
can I pre-mount the z-bar? or just wait... ?
GTBradley
X2 and thank you GTBradley. It was your writeup that I copied and it came out mint.
toadster
I put the Everson & Breeze pieces on in 2014 as I was building the car. Also have the lower radiator support brace which does not show up in the picture
Put the Nomex in about a year later. Its flexable so you can bend & fold it so it will go through the front opening
