Thanks Thanks:  3
Likes Likes:  2
Thread: Nomex honeycomb radiator shield install.
    Raleigh NC, OIB NC
    Had a PM question on this & thought that some pictures would help. Ordered a dirt track Nomex honeycomb radiator panel from SpeedWay Motors along with some button ended zip tie type mounts.
    Sprayed the panel with flat black high temperature rattle can paint. Takes about 2 cans as the Nomex will absorb quite a bit. Made a paper template of the radiator face at the point it contacted Mike Everson's panel.
    Painted the raw edges from the cut & put the panel into the opening against the radiator face. Use four of the zip thingies pressed through the honycomb & radiator fines & pushed the retaining button on them. Unit has about 3 years & is cleaned by blowing compressed air through it from the radiator side.
    Kevin
    MKIV #8234
  2. Thanks Aircontroller, toadster thanked for this post
    Likes Aircontroller liked this post
    Seasoned Citizen NAZ's Avatar
    The stuff works great! Used it on my hot rod but painted it rattle can aluminum and from 8-feet you can't tell it's there. The grill shell holds it in place without any other attachments (at least up to 140 MPH so far). Slides out to clean.
    Dec 2013
    Sewickley, PA
    Very nice! and an easy way to protect the radiator
    Senior Builder lgordon's Avatar
    Dec 2017
    Bellevue, WA
    I really like the clean look with the both Everson’s panel and the Nomex Honeycomb painted black! It’s great when mods like this enhance function, appearance and durability!
    Seattle area; MK4 kit received 5/18; Build completed 3/20; Gen 2 Coyote, TKO600; IRS; Wilwood brakes; PS; PB; Gas-N sidepipes; Vinyl Dash with glovebox; Heater/Defroster; Premium Soft Top
  6. Thanks BEAR-AvHistory thanked for this post
  7. #5
    Conesus, NY
    i did the same as Kevin!! I like the "black hole" effect!
    Chuck Krueger
    MK4 Kit - Picked up 4/5/14, Complete Kit, 3-Link, Wilwood upgrade, Coyote, TKO 500, First Start 7/25/15
    2000 C5
    2003 C5 Z06
    2007 C5 Z06
  8. #6
    Nov 2018
    Centennial, CO
    Nice looking. I discovered that aluminum z bar holds this down at the top and bottom nicely. Plus, it allows easy removal
    https://thefactoryfiveforum.com/show...pproved/page10
  9. #7
    Folsom, CA
    I got this setup, the nomex and a z-bar to mount, I assume I have to wait until the body and any radiator shrouding is mounted - correct?
    can I pre-mount the z-bar? or just wait... ?
    Todd
  10. #8
    Nov 2018
    CT
    Quote Originally Posted by GTBradley View Post
    X2 and thank you GTBradley. It was your writeup that I copied and it came out mint.
  11. Likes GTBradley liked this post
  12. #9
    Raleigh NC, OIB NC
    Quote Originally Posted by toadster View Post
    I put the Everson & Breeze pieces on in 2014 as I was building the car. Also have the lower radiator support brace which does not show up in the picture
    Put the Nomex in about a year later. Its flexable so you can bend & fold it so it will go through the front opening
    Kevin
    MKIV #8234
