Thanks Thanks:  3
Likes Likes:  6
Results 1 to 12 of 12
Thread: Gas Cap
    Heart of Dixie, Alabama
    Gas Cap
    I searched, but did not find, what I thought was there.
    I was fitting parts onto the body, now that I have it close to being positioned on the chassis.
    The gas cap, Stant brand, would not lock on the filler neck. The 3 tabs are too tall to go upon the shoulders inside the neck. After a little dressing of the plastic tabs, they cap twist out of the slots onto the shoulders.
    Surprise the shoulders are not ramped.
    The cap is snuggly in place, but I thought would tighten or hit a stop, neither happens.
    What are some options on this?
    Jun 2015
    Fairfax Station VA
    For quite some time F5 was providing the wrong cap to go inside the housing; sounds like maybe you got one of those. You want a Motorcraft-FC961 cap (https://www.amazon.com/Motorcraft-FC.../dp/B000C5FL84). I've lost the original thread, so I can't credit the builder who figured this out. Whoever you are, thanks!
    MK IV Roadster #8631
  3. Thanks GTBradley, Aircontroller thanked for this post
    Likes Aircontroller liked this post
    Thanks for the info, sure makes it easier.
    I think I will call FFR, no need in me spending $20.
  5. Likes Aircontroller liked this post
  6. #4
    Nov 2018
    Centennial, CO
    Count me in on the same problem. Initially, the cap refused to come out and I ended up using pliers to pull up on it. Now the cap never gets to the clicks. Thanks for the part number to the motorcraft cap.
    Bradley
  7. #5
    Parker, CO
    I thought I was doing something wrong. Mine will click and lock, but comes loose. When you try to turn it to open it, it doesn't move. After nearly breaking it, I accidently discovered I could simply pull it straight out like it wasn't closed. New cap ordered! Thanks for the info.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
  8. Likes Aircontroller liked this post
  9. #6
    ... When you try to turn it to open it, it doesn't move...
    I can confirm this!
  10. Likes Aircontroller liked this post
  11. #7
    Tybee Island, GA
    Here's the version that you can lock
    Motorcraft FC1005 Fuel Cap
    Videos are at: YouTube Videos
  12. #8
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    Think i saw somebody had a fill through cap for these too! Might have been **********.
    Walt
    FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
  13. #9
    I talked to Jay at FFR about the cap. I have the 10832 Stant which cross ref with the Ford number posted. Jay checked their alum filler with the same cap I have. Naturally his fit, but he did find one with the rubber gasket not in place, which would increase the distance in question.
    While I had him on the phone, I mentioned the metal where the tabs ride is flat. No ramps or stops.
    I filed the plastic tabs down and got the cap to twist. There is some resistance with the cap in this position, but if I keep twisting the tabs will line up to remove the cap.
    I do not understand the design.
  14. Thanks Aircontroller thanked for this post
  15. #10
    Parker, CO
    I receive the new Motocraft gas cap from the link in post #2 above and after removing the tether, it is a perfect fit that actually works! Thanks for the tip.
    Legal: 1/30/2020
  16. Likes DadofThree liked this post
  17. #11
    Nov 2018
    Centennial, CO
    Mine did too.
    Bradley
  18. #12
    Cape Coral, FL
    Same here. RockAuto has both locking and regular.
