Likes Likes:  3
Thread: Ride height with gen 2 and 32 nose
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    I took the hotrod off the jack stands for the first time since I installed the cooling system and radiator/grill shell. I've got the deluxe 32 grill. I'm wondering if anyone else has the 32 grill and on the ground in go cart condition. Is there any difference in the ride height from gen 1 to gen 2 with the 32 nose. At 4 1/2" front the grill has 2.25" clearance, seams really low.
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
    Senior Member sethmark's Avatar
    Virginia International Raceway
    You have tons of adjustment....I’m set a 4" currently.
    33 Hot Rod #1133. LS/TKO600
    Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
    Titled 2-28-20
    MkI.IV 2643k
  3. Likes wrp liked this post
    Apr 2019
    Milford NH
    Quote Originally Posted by sethmark View Post
    Ride height in the front or your grill is at 4"?
    Grill.
    Titled 2-28-20
    MkI.IV 2643k
    Sep 2019
    Fredericksburg, VA
    Howdy, is there a way that I could adjust the suspension to something higher than 4 inches?
    What's the tradeoff with that proposal?
    May 2018
    Pinckney, MI
    Quote Originally Posted by Aircontroller View Post
    Just crank up the spring mount. There's quite a bit of adjustment.
    - Peterh226 #1134
  8. Thanks Aircontroller thanked for this post
    Likes FF33rod liked this post
  9. #7
    Senior Member JOP33's Avatar
    Haslet, Texas
    I have my front grill sitting @ 5". I can tell you that I definitely feel more confident driving it around and I am not constantly worrying about every dip or pot hole.
  10. Likes Mrallsport32 liked this post
  11. #8
    Feb 2013
    I was told by Dave B @FFR that the two GEN II mounting holes are for a high and low ride height. Not, that one is for the Truck and the other for the Hot Rod. Like the 818 R and S. The Lower Holes will add about 1" height and is recommended for full fender cars for sure.
    If you are using the lower holes is the target ride height 5 1/5 = this should help with grill hits, I would think.
    Just checking with what others are discovering with ride Height...I do not want to worry about nose hits like I do with my 818.
