Yes on deceleration under high vacuum you can see blue smoke if guides are worn or valve seals have not been installed or installed incorrectly. It would not result in a large loss oil more smoke than consumption. If the PCV valve was the culprit it should affect idle and there should be a lot of smoke visible at idle.
