Results 1 to 13 of 13
Thread: More engine room?
    Feb 2018
    More engine room?
    I realized the type 65 has a 5-inch longer wheelbase so with that said, does the engine compartment have more room?
    I'd like to put a dry sump system on my engine.
    Gorham, ME
    Think they did that on the Lagano coupe, so should be good!
    HTH
    Mar 2017
    columbus ohio
    Much more room than the roadster. Our has a Coyote with two EFR turbos packaged in front of the engine behind the front cross braces. I don't remember the dimensions but I'll measure tomorrow and give you some measurements.
    Chris @ Forma
    Edmonton Alberta
    The hood height is lower than the Roadster so if you are going with Ford small block the air cleaner space is tight especially with a 351 based engine. Otherwise lots of space.
    David W
    Mkll 4874 built in 2004
    Feb 2018
    Thanks guys!
    Chris,
    I look forward to your information. Do you have a coupe or a coupe r?
    If you need more room, consider stuffing in an LS.
    Here's an inexpensive option to look at:
    https://paceperformance.com/i-231575...ngine-376cid-5
    Move the engine forward and you'll have plenty of room for a T56.
    Good Luck & Happy Wrenching!
    Feb 2018
    Godadgo,
    Aluminum block, billet crank and rods, pistons, steel billet cam core...are in house.
    I don't want to do what the trend is however..
    Quote Originally Posted by Jcdata View Post
    Godadgo,
    Sorry but I didn't realize that you had your engine already.
    Also, I totally understand NOT wanting to do what the trend is and I think I'm the only guy with a 383 SBC/Dart, ZF 6-Speed and a 3-Link Dana 44 out back.
    For the record, I really want to build a Type-65 down the road, but I haven't got the budget nor the skills to tackle a Daytona at this time.
    Good Luck From The Dark Dart Side!
    For the record, I really want to do a Type-65 down the road, but I haven't got the budget nor the skills to tackle a Daytona at this time.
    Can’t speak for your budget but as for the skills if you can build a roadster you can build a Coupe.
    Feb 2018
    I appreciate that Steve.
    Thanks for the vote of confidence Sir Jeffski.
    Jun 2018
    Has anyone put a V10 from a Viper? I have done searches and nothing comes up.
    Feb 2018
    Waiting for the cylinder heads and billet steel 54 mm camshaft core.. it will more likely be a 5 stage dry sump system.
    Ross Pistons, total seal rings, Oliver Billet rods, King bearings..
    oh yeah! Here are the valve covers I got custom fabricated.
    Will the new home be in a Coupe or Roadster?
