Thanks Thanks:  2
Results 1 to 3 of 3
Thread: Rear View Mirror Location (Interior)
    Senior Member JOP33's Avatar
    Haslet, Texas
    Where are most of you mounting an interior rearview mirror? Actually into the hardtop above the window, onto the glass, or on the dash?
    I purchased a Hagan Fattie Rearview Mirror to match the side mirrors and the bracket really doesn't allow for the proper angle for mounting into the hardtop. So other options are to mount onto the window, which would work, but will obstruct a portion of an (already limited view) front window. There is also the dash, which would eliminate the need for a second mirror for the roadster windshield, but (to me) really seems to clutter the top of an extremely clean dash.
    Would like your thoughts on this.
    Oct 2014
    Vermilion, OH
    I don't have the hard top but I do have the Hagan mirror and mount on the top of the windshield. I cut the end of the mount off, then drilled and tapped a new mounting hole for the mirror 90 degrees from the the original so it would mount correctly.
    CVOBill
  3. Thanks JOP33 thanked for this post
    I mounted mine into the top and it works well, if you are going to run without the top that may change things, the problem is if you mount it on the dash top I don't think it will work with the top on. Maybe build a blanking plate for the dash mount, when the top is on have a nice plate over the holes in the dash.
  5. Thanks JOP33 thanked for this post
