Thanks Thanks:  11
Likes Likes:  12
Results 1 to 14 of 14
Thread: Valve covers ideas
    Oct 2019
    Valve covers ideas
    Have a 91 5.0 and we have the pretty fined and painted black COBRA valve covers, my question is how to do the PCV system. This originally had PCV in the EFI intake in the valley and had one valve cover with the fill cap which had the port for fresh air into the intake. We are carbureted . Where do you guys put the PCV valve. On a street rod I would just drill the valve cover ,put a grommet in it and go. Any ideas or suggestion?
    Colin
    So. Bay (So. Calif.)
    PCV in the DS valve cover, hose goes to a port under the carburetor. PS valve cover has a breather with a hose into the air cleaner housing. (hose is not connected in the pic.)
  3. Thanks Auto thanked for this post
    Likes Auto liked this post
    Most valve covers that have provisions for pcv have a baffle below the valve inside the valve cover.
    This prevents the pcv valve from drawing in liquid droplets of oil, splashing off the valve train.
    Without this, you will probably encounter, higher than normal oil consumption and or mild smoking.
    I guess there is a rare chance your valve covers might have a shield already in place. I would check before drilling.
    If you can find a filler cap like boat737, put the hose on the tube, use an inline pcv and draw fresh air off the new hole drilled in the opposite valve cover.
    good luck,
  5. Thanks Auto thanked for this post
  6. #4
    Senior Member Norm B's Avatar
    I have the same finned Cobra Powered by Ford valve covers and here are two pictures. The PCV valve is on the back right and the line from it runs through an air oil separator to the nipple for it on the front of the carb base. The breather is on the left incorporated into the fill cap and runs to the base plate of the air cleaner.
    HTH
    Norm
  7. Thanks Auto thanked for this post
  8. #5
    Oct 2019
    yes that's like mine, just hate to drill the cover. Will pull it tomorrow and see if there is a place to install baffle.
  9. #6
    Or forget the pcv and just vent the engine to a tank.
  10. Thanks Auto thanked for this post
    Likes Auto, RBachman liked this post
  11. #7
    Seasoned Citizen NAZ's Avatar
    PCV? What's that?
  12. Thanks Auto thanked for this post
  13. #8
    Jax Beach, FL
    There are EFI (no hole for a PCV valve) and carb (has a hole for PCV) versions of Cobra valve covers. Is there a boss for you to drill? If not, how are going to seal on the fins?
    You do not want to run unvented. The crankcase pressure, and there always is some, will come out somewhere. It could blow the dipstick out (been there, done that, even vented) or it will come out through the seals.
    I am running a half open system like a lot of guys. PCV on the passenger side and and open Moroso separator on the drivers side. Open vents are better for the engine, but messy and bad for the environment. Fully recirculated, gunks up your intake and valves, but keeps the trees and bunnies happier.
    If you drill, you will need to ensure that there is a baffle or you will be putting oil into your intake. Here are a couple things that I learned along the way.
    If you have anything much taller than stock rocker arms, the stock baffles will hit. So, I got slick an made some baffles that notched up closer to the valve cover. ......and here is the problem with that. You actually need the space there, or the air velocity will be higher and the oil won't fall out. I saw some actual testing and it was significant. I put the stock baffles in and got some spacers from here https://medicemfg.com/products_get.p...ers%20-%20Ford. Very happy with them.
  14. Thanks Auto thanked for this post
  15. #9
    Oct 2019
    tried to post pics, don't have that figured out yet.
    It has a boss for PVC and 3 little bosses for screws for baffle
    drill it this weekend and go to parts store and get valve, grommet and hose
    Thanks for ideas and pictures
  16. #10
    Raleigh NC, OIB NC
    If there is no boss try push in breathers with a rubber grommet. Cut the hole Dremel any fin that interferes. Breather sets with a grommet are about $13 & up.
    Started out with hoses, a catch can (can is still on the firewall) & vent hose then switched to breathers to clean up the area.
    Kevin
    MKIV #8234
  17. Thanks Auto thanked for this post
  18. #11
    Get a pcv grommet and measure the outside sealing edge diameter, before drilling.
    The baffle is usually a flat plate that prevents oil from traveling toward the pcv opening.
    After you drill and tap for the screws that hold the baffle and comfortable you have it right, use RED loctite on the screws.
    ,,,don't want those to go mia on you.
  19. Thanks Auto thanked for this post
  20. #12
    Headers.jpgThis is what well ventilated valve covers look like. Unless you live in an area that requires smog checks, this style vent keeps the nasty stuff out of your intake and cylinders. Ever pull an engine apart that's had crankcase gasses or EGR gasses fed back into the intake?
  21. Thanks Auto thanked for this post
  22. #13
    Grand Rapids, MI
    I left the PVC behind many years & miles ago. Two K&N style breather/filters, one on each cover.
    Engine is dirtier on the outside and cleaner on the inside.
    Jim
  23. Thanks Auto thanked for this post
  24. #14
    Sep 2019
    I have a small air filter on as my PCV valve.
  25. Thanks Auto thanked for this post
