Results 1 to 5 of 5
Thread: HELP: Rear Cockpit Side Cover
    Des Moines, IA
    I can't find anywhere in the instructions where it explains how to intstall this piece. Anyone have any pictures of how they installed or can help?
    Thanks ahead of time!
    It covers the triangular area by the rear of the door. I make a different one. see post #222
    https://thefactoryfiveforum.com/show...d-Thread/page6
    Des Moines, IA
    Thanks for the response. If you would have used the FFR piece would you have had to cut it to match the angles\dimenstions? That is where I am stuck...a couple of the angles are off by 1/4" or more...or I am not fitting properly (although seems to only go in one way). Am tempted to make my own as well, but want to make sure I am fitting properly.
    Senior Member AZPete's Avatar
    I tried fitting that piece in every way imaginable, like you have done, then made my own, like Wallace18.
    Des Moines, IA
    Ok...That makes me feel better. Will plan to do the same.
    Thanks for the advice!
