Can an older MKIV body be changed to the MKIV 25th Anniversary configuration?
So it seems that the MKIV 25th Anniversary body is slightly different than the prior MKIV body. If I understand, from another thread, one of the changes allows or makes it easier to use 275/40-17s in the front.
My intentions are to run 275/40-17 and 335/35-17s or the comparable 18s as that's what I'm accustomed too. Rubbing on the inside may cause a concern and be difficult to correct, on the outside, well, it's just fiberglass.
Can the changes be adapted to an earlier MKIV body? Fancy glasswork? Saber saw compass?
Jim
