Thanks Thanks:  3
Likes Likes:  3
Results 1 to 8 of 8
Thread: Coyote to DS Footbox clearance
    Senior Member tbl100's Avatar
    Mar 2019
    Roseville, CA
    Hi,
    I'm wondering if anyone with a Coyote engine in a Mk4 has any clearance issues between the engine and the DS footbox? I have very little clearance and I'm wondering if I'm going to have any issues when the engine is running. The engine installed nicely and sits on the mounts perfectly.
    Tim
    That's about how they fit. Assume you have the FF provided 1/2 inch spacers inside the Energy Suspension motor mounts? If so, that's the current setup and yes it runs that close. Mine is the same way and hasn't been an issue for three seasons and 6,500 miles.
  3. Thanks tbl100 thanked for this post
    Likes tbl100 liked this post
    Heart of Dixie, Alabama
    That looks like about what I have on mine.
  5. Thanks tbl100 thanked for this post
  6. #4
    I have 3 Coyote Mk4 roadsters in the shop currently and they are all exactly like that.
    Carry on!
  7. Thanks tbl100 thanked for this post
  8. #5
    Mar 2019
    Roseville, CA
    Thank you guys. I feel better now. This forum is awesome.
  9. #6
    Mar 2019
    Roseville, CA
    Yes, I have the 1/2" spacers installed.
  10. #7
    Kirkland, WA
    If you find that your DS header touches the footbox (mine did), one of the many 'Kleiner mods' is to put two hardened washers between the DS motor mount and the chassis. Then hoist the engine from the PS and it will slide down on the DS and give you about another 0.040" clearance.
  11. #8
    Mar 2019
    Roseville, CA
    Quote Originally Posted by initiator View Post
    Thanks, I'll watch out for it.
