Results 1 to 3 of 3
Thread: Panhard bar frame rubs pinion yoke
    Feb 2018
    When my rear suspension unloads prior to full droop my pinion yoke hits my panhard bar frame. It rubs with the car on jacks and more importantly once in a while over larger bumps at highway speeds. Has anyone run into this and how was it corrected. Has anyone refabricated the panhard bar frame. I have a 3 link set up 8.8 rear and my pinion angle is properly set. Any help/input would be greatly appreciated.
    wallace18's Avatar
    Trenton, Florida
    Check your ride height. Should be a minimum 4.5" frame to ground.
    Feb 2018
    My ride height is set at 5” frt and 5.5” rear and my tires are approx 25.5” tall all the way around. I should have mentioned before that I have QA1 shocks.
