Thread: Let There be Light!
    Senior Member JIMOCO's Avatar
    Aug 2013
    Camp Hill, PA
    Let There be Light!
    My aging eyes make night driving difficult. I built my roadster using the standard 7" sealed beam headlights. I was very unhappy the way they lit the road. Range was limited and peripheral lighting was non-existent. I am very much used to the more modern lighting system on my daily driver. I tried upgrading to a Hella lens with Silverstar HB2 bulbs. An improvement but still not what I wanted. I read a thread that talked about an LED upgrade using a kit from Breeze Automotive (https://www.breezeautomotive.com/sho...-lighting-kit/). Since I already had the Hella lens and was not upgrading the running, brake and turn signal lights I only needed the LED headlights. Worked with Mark at Breeze and purchased only the headlights. I installed them a couple of weeks ago. Wow! The improvement was outstanding. Much brighter, range of vision much further, road and highway signs clearly visible for a long distance and peripheral vision much improved. With this kit I was able to retain the old school look of the headlights but achieve the results of modern technology. I highly recommend this product. Very easy to install and results are great.
    Mk4 Roadster, Picked up complete kit 8/22/14. Most FFR options except Wilwood brakes and IRS. First start 11/11/14. Go-kart 3/8/15. 347 Stroker, TKO 500, 3-link/3.27 rear. PA street legal 7/29/15.
  2. Likes FF33rod liked this post
    Santa Clarita, CA.
    Quote Originally Posted by JIMOCO View Post
    Do these support low and high beam operation?
    F5R #7841: Anniversary Edition MK4, Ford Racing 427, Edelbrock EFI, Gas-N Pipes, Stainless Headers, TKO600, 3.31 Moser 3-Link, 17" Halibrands
    Aug 2013
    Camp Hill, PA
    Yes. They use the same three prong connector as the other lights and have high and low beam.
    Woodstock ,Illinois
    I have the Hella reflectors with LEDs . Love them! There’s slot of crap out there though that you need to watch out for! A good source of information is Headlight Revolution on YouTube. I learned plenty there!
    Raleigh NC, OIB NC
    Anyone have a "best to use" bulb recommendation for standard socket replacement without making changes to the RF harness. Have Lucas Blue Shield Tri-Bar replica lights with original style incandescent bulbs.
    Don't want to change the harness for top tier lights. Very limited night driving maybe a few hundred miles since registered.
    Kevin
    MKIV #8234
    Aug 2013
    Camp Hill, PA
    Hi Kevin, I have the RF harness with the system I noted above. The only mods are replacing the lens. It attaches the same as the sealed beam. Enlarge the side hole in the bucket to pass through a larger wire and grommet. Drill two small holes and zip tie the transformer to the bucket and reinstall. The RF three prong connector connects directly to the transformer. It took me about an hour to make the switch. My only unknown at this point is the life expectancy of the LEDs. Time will tell but not until next spring.
  8. Thanks BEAR-AvHistory thanked for this post
