Fuel Safe Systems
Results 1 to 3 of 3
Thread: HAWK Coupe early winter updates
    Huntsville, Al
    Just got back from SEMA and finally slowed down a bit to post some updates.
    Pretty much have been driving the car all year! Fantastic chassis for sure and the car hasn't let me down....
    About 1 month ago I noticed some oil on the ground by the right tire - figured I would keep an eye on it not sure where it was coming from honestly... a ton of plumbing in the car... About 2 weeks ago I noticed the air filter had a wet look to it...
    so I pulled off the filter...
    well oil isn't supposed to be there or here:
    So I guess the upgrades started early...
    off with the turbo: add because I don't do anything half way - yup the other turbo was on its way out too just hadn't leaked to the ground.... so both sides looked like this before SEMA
    While the turbos were gone I added a remote adjuster for the brake bias... still going with the aviation theme... this was version 1 - the second one I just changed the font some...
    Huntsville, Al
    And - since in order to do this upgrade I had to drain the intercoolers and remove the driver's side to gain access to the pedals....geez!!! might as well work on the intercooler system
    I felt like I needed more volume in the system - in standing traffic in 100*+ weather it was taking a bit to cool the system... so ... I had some extra aluminum around and have never built a tank before....meh... why not!
    I took the existing tank and cut the side of it off and just made the tank "longer".... I think it came out pretty good... and since I kept the original tank all the fitting still worked!
    Cause of the turbo failure was determined to be the wrong size oil feed restrictor when using these turbos - turns out what I thought were ball bearing turbos are actually "hybrid" turbos .. they have one ball bearing and one journal bearing...
    you can see the difference here:
    anyway - back from SEMA yesterday and one of the Turbos was here waiting for me.... so ... 1 in and ready!
    wallace18's Avatar
    Alachua, Florida
    Nice of you to share this will all of us. Like I tell folks these are not OEM cars and will always have something ti tinker with. Glad you are enjoying the ride so much. It is a super example of craftsmanship.
