Thread: E brake spring modification
    Lake Mills, WI
    Hi Guys,
    I can't find the link to the info on the spring for the e brake mod.
    Can someone post the link or item information on the spring needed.
    PS-I have the FFR supplied performance brakes.
    Are the E brake cables suppose to have a E-clip to hold the cable into the caliper?
    Mine did not come with any E-clips, but I see a under cut ring in the e brake cable.
    Thanks for the inputs
    Martin
    Jun 2015
    Fairfax Station VA
    I used a pair of 3-1/4" length, 7/16" O.D., .062 wire gauge (Hillman Item # 540120, #40) springs. I also added a pair of 1/2” E-clips to secure the cable sheath to the bracket.
    Note that this is for the Wilwood setup with the parking brake integrated into the caliper.
    IMG_3526 by jhsitton, on Flickr
    MK IV Roadster #8631
    Senior Member lewma's Avatar
    Jan 2018
    San Marcos, CA
    I did a very similar mod to mine and its working very well.
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
    Blue Oval Scribe Mustang Man's Avatar
    Lakeland, FL
    While not FFR related, it is essentially the same parts. Upgraded my Fox Mustang to rear disc/five-lug many years ago. They use the same parking brake cables and you can get the correct Ford clips from National Parts Depot (major Mustang restoration parts company). Not sure where you are located, but they have retail ops in CA, MI, NC, and FL, and obviously mail order.
    https://www.npdlink.com/product/clip.../205683/160111
    HTH!
    Mark
    Modified Mustangs & Fords Project Snake Charmer
    FFR5310 Mk 3 Roadster
    Tungsten Gray/Silver Stripes
    Lake Mills, WI
    Thank you guys
    Huge help. Have a good weekend
    Martin
    PS Ford vs Ferrari.....
    So. Bay (So. Calif.)
    The springs I used were Century Spring C730, 13/32 x 2 ¾ x .047 (from True Value Hardware), which looks to be 1/2 shorter, and smaller wire dia. than John's. They seem to work. No hang ups or sticky pads. (I have the 3 link straight axel, different caliper it looks like. Mine are Wilwood).
  7. Thanks phileas_fogg thanked for this post
    Lake Mills, WI
    boat737
    Are you using a E clip to hold the ebrake cable into your caliper?
    M
    Quote Originally Posted by magicmarto View Post
    boat737
    M
    No I'm not. Either they weren't noted in the manual, or maybe I missed that instruction. Bottom line is there is nothing holding the cable housing in the mount/bracket other than not enough slack in the inner cable to allow it to back out. Haven't had any issues with the cable housing end backing out of the bracket. So far working fine.
