Thanks Thanks:  2
Likes Likes:  3
Results 1 to 10 of 10
Thread: Performance Alignment
    Member Swamplife2's Avatar
    Nov 2019
    Conway SC
    In my old Saleen days had the specs for a front end performance alignment done with my more than adequate weight in the seat
    Anyone have roadster alignment specs they found to be good and will share for our machines?
    1414K
    Less is Less
    Street car with manual steering;
    .5 to .75 degree negative camber
    3 degrees positive caster
    1/16" to 3/32" total toe in
    With power steering go to 7 to 8 degrees positive caster
  3. Thanks Swamplife2 thanked for this post
    Likes Swamplife2 liked this post
    Nov 2019
    Conway SC
    Will use your specs. no power steering (only power anything is engine)
    Thank you
    Last edited by Swamplife2; 11-15-2019 at 07:41 AM. Reason: made better and more thanks
    1414K
    Less is Less
  5. Likes BEAR-AvHistory liked this post
  6. #4
    Nov 2019
    Conway SC
    PS
    Waxing bad, driving good
    1414K
    Less is Less
  7. #5
    Jeff,
    How bad would things get if the caster was pushed to 4 degrees?
    My rack is about 3.5 turns "Lock to Lock" so I was wondering if this limit could be pushed a little.
    Grand Rapids, MI
    Couldn't agree more.
    Jim
  9. Likes BEAR-AvHistory liked this post
  10. #7
    O'Fallon, MO
    Jeff,
    Nothing bad will happen, maybe just a bit stiffer turning it a low speed. Keep it above 85, it'll turn smooth.
  11. #8
    Thanks!
  12. #9
    As Rich said nothing bad will happen but more positive caster=higher steering effort. You have a very slow ratio rack and with a slower ratio comes lower steering effort so you can probably go up a bit without the effort becoming uncomfortably high. Feeling strong?
  13. Thanks GoDadGo thanked for this post
  14. #10
    Lost Wages, Nevada
    FWIW, My MKII is set at +3.5° with 275x40x17's up front with a 4 turn lock-to-lock Flaming River rack, 22# air pressure up front - and in 18 years, I have gotten very used to the effort to park and it's not an issue for me.
    Doc
