Fuel Pump Questions
I'll be running a carb'd 306 in my car and curious what other SBF builders who have a carb set-up went with for their fuel pump, mechanical or electric, and why? Also, if you went with an electric pump, where did you install it?
Thanks in advance.
Tony
MKIV Complete Kit #9494 l Delivered 1/5/19 l First Start
11/28/20 l First Go-kart
4/11/21 l Carb'd 347 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Upper/Lower Radiator Support, Fan Shroud l Boig Upper/Lower Cool Tubes & Quiet Pipes l 18" FFR Gasser Wheels l
