Results 1 to 2 of 2
Thread: Turn Signal Bezel Falling Off...
    Senior Member cv2065's Avatar
    I took my turn signals apart to have the bezels powder coated. I don't recommend doing that as putting them back together is a bit of a challenge with delicate pieces. Anyhow, the bezels are press fit on to the turn signal, and almost look like a one time deal, as once they are removed, the tension of the press fit is compromised. Rear tail lights are screw in, so not sure why FFR selected these. I put a little silicone on the areas that make contact, but wasn't enough to hold. Was thinking about maybe a set screw of some kind but didn't want to jack up my PC.
    Anyone run into this?
    While fitting mine, for the first time, I had to remove the chrome trim ring also. I was surprised, it is a friction, press on fit. I think more rtv might be the easiest answer.
