Thread: Pro-Shock springs?
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Pro-Shock springs?
    Anyone have a set of the original Pro-Shocks that can tell me what weight springs were included?
    I've pulled mine from the car and there isn't anything on the coils indicating the weight rating.
    Ray
    Woodstock ,Illinois
    The build manual should have that info!
    Senior Member tonywy's Avatar
    Nanticoke, Pa
    I have fronts only on a MK II and they are marked "500". The rears are Koni "350". This is a big block car.
    Wareham
    The Pro shocks came with a couple different rates over the course of production, but the most popular for a solid axle during that time was 450 front 250 rear. On those older springs a lot of times the rate was etched into the end of the spring as well.
    Jim Schenck
    Factory Five Racing
    Member 7tvette's Avatar
    Sherwood Park, Alberta
    My Mk 111 Pro Shocks are #450 front and #250 rear. Still holding up great, even with my fat *** compressing them!
    Troy
    " The journey is the reward" Chinese Proverb
    FFR Roadster #5380
    FFR Spyder GT #030
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Quote Originally Posted by Jim Schenck View Post
    Thanks Jim...
    Looked at the end of the coils and there it was.....450 for the front and 200 on the rears,,
    Love this place
    Ray
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Ray
