High Flow Engine Oil Cooler
Hey guys,
Has anyone used something similar to the automatic engine oil cooler thermostat part from Improved Racing below?
http://www.improvedracing.com/oil-th...tat-p-212.html
I plan on running the Lingenfelter oil cooler adapter plate which will feed filtered oil towards the cooler, but I want to run the above to control the temp at which it actually flows to the cooler in order to allow the motor to warm up properly and not over cool oil. I can choose the temp for this thermostat block to open at (145, 165, 185, 205, and 215).
What would you guys recommend as a temp for this thermostat for an LS3/427 that dynode at out 625hp?
Thanks for your help.
