I have the body sitting pretty good on the chassis. I bolted the side pipes on with gaskets. The drivers side is pretty good up and down, only a slight angle, maybe 1/8" from front to rear.
The passenger side has a 1" increase in distance from the body, front to rear.
I am considering adding the washers under the drivers side motor mount. I need a little more clearance on the foot box. I think I can get the drivers side pipe parallel to the body.
I looked at Mark's exhaust wedges. His selections show various increments of inches.
Is this the amount of run out it corrects for?
Also, can I run the wedges and or side pipes with hi temp rtv?
If not, I guess a gasket on both sides of the wedge.
