Thread: Side Pipe Adjustments
    Heart of Dixie, Alabama
    I have the body sitting pretty good on the chassis. I bolted the side pipes on with gaskets. The drivers side is pretty good up and down, only a slight angle, maybe 1/8" from front to rear.
    The passenger side has a 1" increase in distance from the body, front to rear.
    I am considering adding the washers under the drivers side motor mount. I need a little more clearance on the foot box. I think I can get the drivers side pipe parallel to the body.
    I looked at Mark's exhaust wedges. His selections show various increments of inches.
    Is this the amount of run out it corrects for?
    Also, can I run the wedges and or side pipes with hi temp rtv?
    If not, I guess a gasket on both sides of the wedge.
    Port Charlotte, FL
    RR,
    The wedges are the way to go. I use the copper rtv with no issues. Yes, it is the amount of the runout it corrects. You can also drop down to 5/16 bolt to get a little more wiggle room up and down.
    Henry
    Quote Originally Posted by 65 Cobra Dude View Post
    RR,
    Henry
    Ditto On The Wedges & 5/16" Bolt!
    https://youtu.be/wOID7yvBRPU
    Use Grade-8 Not Stainless!
    X3 on the wedges. They are available in different thicknesses and can be stacked to achieve the proper alignment.
    https://www.breezeautomotive.com/?s=...t_type=product
    Thanks for the replies and tips. I really like the 5/16" bolt to get some wiggle. Will pick up a tube of copper rtv and get to work.
    I am trying to get licensed by the end of the year or early next year, Then to paint.
