Thanks Thanks:  2
Likes Likes:  8
Results 1 to 12 of 12
Thread: Evaluating Aero effects
Hybrid View
    Jan 2019
    I was looking at some way to measure shock travel so I could evaluate wing angle and front chines etc. RacePAK at $1200ish was out of my range. I found sensors on eBay from an Australian auto sports company. I have looked at stuff on Alibaba before but never purchased it. I found sensors that were the same specs as the Australian pones for $23.00 each including express shipping!!! Here they are: I am going to use 1/2 coupling nuts to mount the rod ends on to the end of the shock mount bolts. Awesome huh. $94 for all 4 shocks I will be able to also compare chassis roll with and without a swaybar.
  2. Thanks Scargo thanked for this post
    Syracuse, NY
    Very interested in doing something like this to evaluate aero loads. Can you post the details of where you got those linear sensors?
    MK3.1 Roadster completed 2011
    Jan 2019
    Search Alibaba for the below page.
    Let me know if I can be of anymore help?
    Senior Member q4stix's Avatar
    Seattle, WA
    If those work I may have to order a set for myself just because I'm curious how my suspension redesign will act. Are they just an analog voltage output vs. deflection?
    Gen 3 Type 65 Coupe builder
    Jan 2019
    Yes, DC in up to 48vdc and a variable output vdc as a result of its position.
    About 10 years ago i need to do a data aquisition system monitor an EV during a driving cycle. It worked very well and was cheap. this would work great for moitoring 4 shocks.
    https://www.dataq.com/products/di-11...4aAt9GEALw_wcB
    Jan 2019
    I’m fortunate I’m running the Haltech ECU, with an I/O board I can monitor them with that and over lay g forces speed and gps data.
  9. Thanks walt555 thanked for this post
    Likes biknman liked this post
  10. #8
    Sep 2015
    Hamersville, Ohio
    Quote Originally Posted by Brd.Prey View Post
    Are you using the 1500 unit? I’m running that one myself. Lots of input options.
  11. #9
    Jan 2019
    Yes 1500 elite. Not hardly enough inputs, I am having to add a canbus A and B I/O box.
  12. #10
    Reno, NV
    Awesome. Please let us know how they work out.
    818R Build date 10/31/15
  13. #11
    Jan 2019
    Will do
  14. #12
    Jan 2019
    Installation was easy. I am wiring them in to a I/O extender for the Haltech. I made up Deutch connectors for it all. Now get the car done and out on the track.
  15. Likes aquillen, Hobby Racer, Mitch Wright liked this post
