Thread: Loomking for some 89-93 EFI parts
    Norton, MA USA earth
    Looking for the following parts.
    A9L
    aftermarket throttle body
    Cobra upper and lower or similar
    any sensors for this setup
    Converting a 94 motor to run on a Painless 89-93 harness
    Thanks Mike
    "The I.E." SoCal
    A9L
    Thanks Mike
    Mike, I think I have an A9P, Stock throttle body, Cobra upper tubular and lower with a coolant temp sensor.
    I'l double check over the weekend and send you an email.
    Edit: you're probably going to need another distributor as well. I may have one of those.
    __________________________
    Frank. Customer bought a new distributor.
    mburger's Avatar
    Punta Gorda FL
    Mike, I have a known working A9L. I’ll send you a PM.
    Mark
